4 Near new Driftek 17x8" Wheels Multistud 114.3 +34
2 95% Nexen N3000
2 x 70% Yokohama Advan Neova AD07 (1 Flat Spotted due to front brake lockup)
4 x Zenkei 17x9" 5 x 114.3 +34
2 With worn Yokohama AD48 Semi Slicks, and 2 With usable 225/35/17 Street Tyres
$680
4 x S15 Wheels with Worn Tyres (1 Flat) $180
4 Used 215/45/17 Dunlop Formular R Slicks - Still ok for a couple of track days $280
(Left over from testing for this years Australian Mini challenge)
4 x Sparco Racing Wheels 16x8 +38 and 16x7 +34 Multistud with worn A048 and Re55 semi Slicks $380
(all centre caps included but 1 needs repaint)
I also have 2 new Nexen N3000 235/45/17 $200 the pair.
Edited by Brokenz
  • 3 weeks later...
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
