they fit a 4x6 in those doors from factory . if you were to do a 5x7 on a custom plate it would work as well. make sire you retain the rear tab when you do. otherwise everything in the door pocket will slide INTO the door.
common speakers that people use in them are 6.5" - watch the depth if you do this.
lol I installed pioneer 6.5 splits today and had the problem with depth using 12mm mdf. So decided to buy pods instead
Hey ppl
any one know where they sell front 6x5 speakr pods for r32 in Adelaide?
I'm guessing autobarn??
I fitted 6.5" rockford fosgate splits (t1652s) into an r32 gtr for a customer last week, tight fit but all good!
l at the moment I carnt wind my windows down coz of the f**kin magnets errrrrh anyone used16mm Mdf instead? Anyone had this problem?
Edited by r32man09
which is why I said to watch the depth of them...
somthing to bear in mind as well.. the stock mounts are raised and angled. dpulicating that will fix your clearance issue. takes a bit of fiddling to duplicate teh mounts properly but if certainly fixes the depth issues.
Ok Im just going to use 16mm that should fix my problem I hope...
