Time for a change, owner of this vehicle for the past 3 years. Bought as stock standard car. Tasty mods with potential 270Kw with upgraded injectors.
Reason why i'm selling this car is because I have upgraded to a modified s15, something different...
Year: 1996 Series 2
Km's: 160XXX
Colour: White (Brand new paint)
Rego: ADIS (till 11 AUGUST)
Transmission: 5 speed manual
Price: $10K ono - I have spent more than $10k in mods alone.
Contact: SMS 0421 864 698 /PM or post in thread
Power: 230KW @ 14psi
list of mods:
Motor/Engine Bay
* High flow G2 500HP turbo ($1370) HYPERGEAR
* Nistune Z32 ecu tuned by DR DRIFT ($1100)
* Splitfire coilpack($550)
* Bosch Fuel pump ($300)
* Blitz Pod filter with custom 3inch intake ($300)
* Front mount intercooler,return flow. Tanks are HKS ($300)
* Turbotech boost controller T set to 14psi ($30)
* Full exhaust with twin tip at the end ($500)
* Exedy heavy duty cushioned button clutch ($900)
* Brand new O2 sensor($90)
* Brand new fuel filter ($40)
Wheels/Suspension/Exhaust
*350z Wheels with Toyo rubber-225s ($600)
*Tein height adjustable coilovers ($800)
*Full exhaust with twin tip at the end ($500)
Inside the Cabin
*Boostgauge/oil gauge with Apiller ($120)
*HKS turbotimer ($60)
*Nismo Gear nob ($50)
*JVC mp3/ipod/usb player($350)
*Pioneer 6"front+rear speakers ($200)
*Rear Skyline floor mats
Exterior
*Fiberglass Bootlid, no spoiler or holes ($300)
*Professionally tinted windows ($300)
*Brand new paintjob ($3000)
Stock parts available:
* Stock exhaust
* Stock intercooler+piping
* Stock Air Filter box
Car service:
*General service done 3K ago
*Front brake pads changed last week ($100)
Note: Compression test was done last year with 155 accross all 6 cylinders. Any test welcome. No time wasters or low ballers but reasonable offers WILL be considered.
Note: Bootlid does not sit flush and is not a perfect fit and not a perfect colour match. Therefore if the car is sold i will re paint the boot or supply a perfect standard series II boot with spoiler.
The car will be listed on CarSales and other websites. Thanks for looking.
https://www.sau.com.au/forums/topic/343817-1996-r33-turbo-series-2-230kw/
Last time I changed my mind about selling a good car but this time I'm serious. I have already purchased my new car therefor I'm looking to sell asap to the right person. Pictures of engine bay will be up tonight.
Car uses 11L/100km so great economy to power ratio.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
