For sale: 1989 MX83 1JZ
Item Condition: Good condition
Price and price conditions: $6200 ONO NO SWAPS
Extra Info: Well i've decided it may be time for me to move on from this project. I've always wanted 1JZ Cressida and now I have done it, it's out of my system.
Contact Details: PM, here
- Car is rego'ed till the 17/11/2010
- The engine is from a JZA70 and has approx. 80,000kms on it. Installed at 73,000kms. Car has 23X,XXXkms. Engine feels very strong on boost, never been boosted past 10psi and only mod to the engine is a 3inch mandrel bent intake pipe.
- Motor is mounted using JZX81 engine mounts.
- Stock radiator with AU thermo fans wired to a temp switch. NEVER been over half on the temp gauge.
- Has a 2.5 inch exhaust system all the way through with a small muffler down the back. Sounds angry when it hits boost. Very quiet @ 60km/h.
- GA70 FMIC with 2.25? inch piping.
- Transmission is a W57 with a 7M clutch. Using a 2JZGE bellhousing. Gearbox feels nice and strong and is not noisy.
- Interior is very nice for the age and kms. No wind noise from door seals.
- Boost gauge.
- Battery in boot
- Everything on dash cluster works including Tacho (made signal/ign booster).
- Pioneer CD/MP3 player with 6x9 speakers in the back.
- Exterior is as plain as it can get. Stock paint, stock mudflaps, stock towbar and stock s14 wheels (does not come with 17's pictured, they are sold)
Known Issues:
- car needs wheel alignment.
- small oil weep from sump.
- rear discs may have excessive runout (slight brake pedal pulsation)
- A/c not hooked up. Will supply 1JZ compressor upon sale.
- LHR window does not go down (switch)
- bonnet struts need regas
Car makes 151rwkw on 10psi. Surprises alot of people at how quick it goes and it would be an animal with an aftermarket ecu and more boost.
Used as a daily driver and is nice and comfy. Have gotten 10L/100km numerous times as it is quite economical off boost.
Anyone interested can PM me and organize a time to look at the car.
Car will be driven by me only, no joyriders unless a deposit is paid.
Pictures:
Cheers
Andrew
https://www.sau.com.au/forums/topic/343836-fs-1jz-mx83-toyota-cressida-1989/
I cant reply to PM's sorry guys - post count too low.
Car is not registered with the 1J. It can be engineered, I believe, if the brakes are upgraded to R33 Calipers and Falcon disc rotors.
Cheers
Andrew
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
