I'm looking at buying a set of WORKS S1 rims 19" x 12.5 for the M35. What offset do they need to be and are they fine for a brake upgrade? Also is there a straight fit DBA slotted rotor swap available.
Sorry to ask once again but the brake section is out of control.
Cheers.
https://www.sau.com.au/forums/topic/343849-rims-for-the-m35/
19x12.5? :D Any offset you like, not going to fit under the guards anyway...
The widest confirmed (non ridiculous) fitment in a 19" is around 9.5" wide, at +35 offset. No guard rolling or clearance issues.
Brake discs are 350z touring (non brembo). RDA's are probably better value for money, approx $350 front slotted, $250 rear slotted, retail. You should be able to go ceaper than that if you look around.
Edited by Daleo
Ok. I only stated that rim size because the site said that's the size available in the 19" riim so I guess those aren't gonna fit.
I probably should have just asked what the M35 standard off set was.
Cheers for the reply.
+40... I think...? Anyone confirm?
I think Keir prob has about the biggest I know :D - 19x9.5 +30's
Stock 17x7" is +45, ARX 18x8" is +40. In an 8" they need at least +30 offset, even +25 offset would go fine without clearance issues.
Just need to allow for caliper clearance for further down the track if you're going to upgrade.
My bad, I thought his were +35 :) .
Edited by Daleo
My bad, I thought his were +35 :D .
yup you made me think about it also.. +30 offset for mine on 9.5's x 19
with about a fingers clearance from the strut tower. no scrub on 245s all round either (at full lock which is cool) but the front if i bottom out hard enough will hit the gaurds so they'll probably need a slight roll (they just sit out by about 5mm)
not that its ever bottomed out yet.. just a concern on tyres worth more than my r33. :)
Edited by PetroDola
Oh, and just incase you haven't found it yet, everyone is pretty much in consensus that you can't run staggered wheels, because it screws with the AWD system.
(sneaky little point, since your a series 2 M35, you can pull the fuse, make it RWD, and run staggered rims, but only in RWD mode...)
not that its ever bottomed out yet.. just a concern on tyres worth more than my r33. :P
Does the axis have flared guards or is that just body kit to make them look like they are flared. I'm talking about the AWD series 2 model, similar guards to the AR-X.
you can pull a plug on the series 1 too.. have had it done for over 8 months now.. so much better to drive with stock power..
i run 18x10+20 on my m35 at the moment. the front only slightly stick out the guards. but it does need to be a little lower.. the rears is only a touch out of guards and look fine..
this is a non arx m35..
i can get good prices for rda and dba brake rotors.. i havent priced up the dbas yet however but my friend moves alot thru his store and gets good prices.
Interesting angus..
Im sure i read in another thread somewhere that it was possible with series 1 m35's for the fuse trick but it ended up having a detrimental effect on the attessa and the hicas on arx's eventually regardless? or something? anyone verify that ?
Edited by PetroDola
Excellent, I will be calling on you come time to get the brakes done.
Still might go for 18's as it may be a safer option once the car has two kids, wife and dog plus luggage in the back.
Not really interested in the Staggered Rims and AWD. Maybe if I had bought the Axis S. ;):bunny:
Interesting to note:
Axis Autech runs a 225/45/18 tyre which gives an approximate rolling diameter of 660mm (assuming no weight on the tyre though)
I've been told you can run a commodore tyre which is 235/40/R18 (which should be cheaper) but the dia is smaller at 654mm
Anyone know what an RS Four runs from factory?
Is it a 215/55/17? (giving a diameter of 668mm)
215/55/17 is correct.
On my 18s I run 245/45/18, this takes the factory 9% speedo error to about 3%, fills the guards a bit better, and rides better than 225/45/18. It's also std rubber for VE commodore 18's, so well priced too.
Hmmm. Interesting. Got any photos Dale?
245 is a wide tyre! (well for me anyway)
On about pg 34-36 of the "What have you done to your Stagea" thread, or I'll put some up tomorrow for you.
Rubber sits basically flush with the rim edge. I reckon your AXIS rims would look tough then, mine do.
So I guess these aren't gonna fit either.
http://www.skylinesaustralia.com/forums/Wo...-F-t340622.html
Bummer. I know it's an M35 but I just like the look of a race wheel.
Agreed, they are a beautiful wheel, especially in that width/offset. You'd be doing some pretty serious guard pulling to get them under, and I'd say you'd need to stretch a 245 or something to make it work.
Probably better to keep looking for a less aggressive offset...
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
