Hey, I was wondering how much it'd cost to paint a bumper, rear or front. Like i've seen cheap modded bumpers on eBay and places like that, but they still need to be primered and painted. Is it hard to find a place that has the specifc paint, like the car's paint has faded a bit and i wanted it matching that.
Also a complete paint job, are there any decent places in NSW that would do it cheap, e.g under 1k?
(skyline r33)
And lastly I wanted to know about a side vinyl, i wanted a vinyl/decal/graphic along the side of the car, but a really large one, covering the entire side, over the door and front and rear side panels of the car. How much would that set me back? And again, any cheap places in NSW?
Thanks in advance.
any paint panel shop worth there salt will paint match fairly accuratley for you.
a full respray under 1k, unless its a can job or backyardy and your good mates its a NO.. if u do prepwork painting will be cheaper but stil not likely a 1k
the vinyl that'll cost you nothing, i say that cos its super ghey and for your own credibility i dont recommend doing it unless its for business purposes.
having said all that im from melb so maybe stuff is cheaper in nsw... good luck anyways
Alright, forget the paint job i guess. What about painting the bumper/body kit myself at home?
and for the vinyl, i want it across the side of the car, really large.. it'll cover a few paint blemishes too. but yeah, anyone know of a cheap place in NSW for it?
hey man i bought a black front bar for my 32 and resprayed it to match my maroon.. i was actually really suprised how good it looks.. if its the same color as ur car then youl just wana sand it back a bit 180-400
grit then get ur paint code and get somewhr like autobarn to mix u up some spray cans i used about 4... but that was from white and get a couple cans of topcoat clear unless your pretty mch inspecting it youd never tell the difference :thumbsup: hope this helps!
simon
if you don't have a compressor and a spray gun, then the bumper at home is a waste of time. any panel shop will be able to do it for a few hundred bucks and have it matched to your car pretty well. i had 3/4 of the car painted by a mate who's a panel beater and only in certain light at certain angles can you tell the difference, and that is only because the painted panel is sitting right next to an original panel (door to roof) and you can just tell that the roof is more faded, but that will be getting done in the future since the clear is starting to lift in 1 small spot.
I design and produce vinyl graphics for street, track & race cars, and not crappy off the shelf type stuff, this is full custom designed to suit the style of the car and owner...
www.metal-ink.net
generally though if your after cheap, it will look cheap... do it once do it right...
The trick is to get as much painted together at the same time as possible - as it would be cheaper for the panel beater to buy paint and do it in one hit.
In general, getting both the front and rear bars painted and fitted would not cost over $1K.
In regard to the stickers or body vinyls as some may call it, I personally suggest you stay away from them, but if you like that sort of look, it would cost around $400 plus labour at some rate to get it done. I wouldn't pay more than $500.
There's nothing wrong with Ebay bodykits, but just make sure you do your research and read the sellers feedback, as you'd get a good feel of how a seller does soon.
Good luck..
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
