Rb26 Egine Parts
Hi i have some rb26 parts for sale
rocket covers and timming cover $400
head with buckets shims standed $1000
2 standard cams $250
6 throtle bodies $100
r32 gtr intercooler no leaks $200
almost new heavy duty clutch kit $150
brand new N1 pump brand new in the box $450
two turbos and manifolds $300
power sterring pump and bracket $150
standard fuel rail $60
720cc injectors just been cleaned and flowed $500
left hand side electric window motor and rail $50
2 standard front caster rods $30
lots of small bits
Hi.
What condition is the head in?
Does it need a reco.?
Can I get a freight quote to 3029?
Thanks.
hi mate the head was on a good running engine mind you if i was going to run it i would get a reco as it came off a 91 model car as for the post im not sure my post code is 2560 and im happy to box it up for you thanks jason
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
