Given points don't even cross state lines (aka 3 points lost in NSW won't effect your Vic license) I doubt an international licence would gather points.
There is talk of them changing the state rules though but it hasn't been done yet.
https://www.sau.com.au/forums/topic/343883-demerit-points/#findComment-5553763
hahaha,
that is awesome.. what about this scenario then...
say you hold a Victorian drivers licence, you get booked in NSW and lose your licence, can you go back to Melbourne and keep driving on that same licence?
https://www.sau.com.au/forums/topic/343883-demerit-points/#findComment-5554209
yes i believe...the laws a stuffed and are different from state to state....i know a guy who lost his licence here but before the date, he went to sydney and made a nsw licence and it was valid in vic and kept driving here even though his vic licence was suspended...wierd ey..
https://www.sau.com.au/forums/topic/343883-demerit-points/#findComment-5555015
hahaha,
Wrooooong.
Points do transfer.
Lose license in Vic and they will inform every other state and you'll be done there too.
In fact, interestingly, if you get done in Vic for say 8ks over, which is a $110ish fine and 1 point, once the RTA gets wind of it it becomes 3 points.
https://www.sau.com.au/forums/topic/343883-demerit-points/#findComment-5555975
The transfer between States is only very recent and may not apply to all scenarios. With a cancelled licence in Vic, someone who shall remain nameless relocated to QLD and got his licence up there nearly 2 years ago. However he has since gone to renew his QLD licence as he eventually moved up there anyway and his Vic points have now been added. This was back in August.
I came to Australia at 19 with my UK licence (the UK licence used to be on watermarked paper before photocards). I was able to drive freely with no P's and once I realised I would be here longer than 3 months, sat my test. I only had to do a theory test as the UK test is hard but the main reason for getting the Vic licence was to start getting a credit history. When they issued it, they put a black stamp on my UK licence saying Vic Roads Licence Issued XX/XX/XX. This was incase I handed my paper one over if I was stopped. Just applied for a new photocard one a few weeks later and said I had lost my UK paper one.
As for points, they don't accrue on an international licence, however if you are Aussie living O/S but back here driving on holiday and get pinged with a camera, they will pursue to your country of residence! This is from experience.
https://www.sau.com.au/forums/topic/343883-demerit-points/#findComment-5556143
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
