Thanks for all the info. Good read. Sounds like I may as well stick with the GT25/30 for now. Like I said I don't have any problems with it at the top end.
Are there any decent twin-turbo SR20s around? Would there be any significant gains in response/low end? Or more hassle than it's worth?
Edit: To the above, I have no preference to brand; are there any good rivals in the low end response catagory?
Edited by Nissinja
Also that GT2860RS is virtually the same as a 2530 but is compressor wheel is a slightly more modern design .
In an effort to utilize an existing thread;
I am considering running 2 x 2860RS discos on my 1JZ
I am confined to my .48 AR turbine housings however wont have much hassle going to a better compressor housing (oem housings are .30 AR for compressor).
I am thinking of using the native .60 t04 cover off the disco itself, however fear it may create an inbalance with the turbine housing. Alternatively I was thinking of machining a set of 2560 covers on (still .60 AR).
While we are on the topic of SR20 based turbos, what are some opinions on the above?
I am figuring seeing as 2530s have an outright flow of say 450rwkw in max tune, perhaps the right comp cover in my .48 housings would yield a potential within 100rwkw difference? I am assuming the compressor cover will be the deal breaker.
zero low end and response with a twin :) i had a twin sr20 (tdo4's) on display in my old autobarn shop in sa for a few years
Well GT2530s have always had 0.64 A/R GT28 based turbine housings and I pretty sure a variation of a T04B sized compressor housing , the way to tell is to see of the comp housing has and adapter ring between the bearing housing and the comp housing . If the comp housing is held in by the circlip directly on the back of the comp housing its smaller .
For OE RB26 sized housings possibly 34GTR GT2556R's or 707160-9/GTSS turbos should be more responsive .
I'd have thought a single turbo conversion on a 1JZ would be simpler , much simpler that the sequential turbos I thought those engines had . Maybe look at the new BW range for something suitable .
I can't see any advantage of parallel twins on an inline four , You'd need to have one feed off cylinders 1-4 and the other off 2-3 so one would be on top of the other in a plumbing nightmare . I reckon you could do better with a custom manifold and an Evo X specific TS TIW GT3076R .
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
