How Does The Physical Operation Of Vct On 25s Work, Could It Be Adjusted?
I'm curious how the VCT on rb25s physically works, from what I gather when the solenoid is on it allows oil pressure to reach a part of the cam and essentially changes the cam timing much like a cam gear does.
Would it be possible to effectively tune this for different operation, eg changing how much it does retard/advance the cam so that you can get even more advance, then just shut it off around 3500rpm instead of 5000 rpm?
Would be much better than cam gears as you could only activate it for whatever part of the rev range it is effective, instead of shifting the entire curve either compromising low down power or high end power.
Edited by Rolls
you can change when in the rev range with most aftermarket ecus, as for how much it can change the timing I doubt there is any way of modifying it.
yeah I use my eboost street to control the rev range, just wanted to know the actual physical operation to see if you could increase the gap between x and y to cause it to shift further or less, or whether it is dependent on oil pressure and in that case you could PWM a solenoid so that it can be adjust between fully open and closed.
I guess adjusting the oil pressure going to the cam might do something useful, But who's to say you actually have any amount of fine control
and that is why I posted this thread to see if anyone had a deeper understanding and could tell me that...
Being able to accuratley adjust cam timing between the limits of the vct unit would be almost impossible, it's designed to be either on or off. You'd need a seperate oil system that can be accuratley adjusted as well as some way of measuring the advance/retard of the cam and whether or not that would work is any bodies guess.
I pressed an old one apart at work out of curiosity and found it has a piston with a helical cut spline on the outside diameter which mates in to an internal helical spline in the outside housing. When the piston is moved back and forth the helical spline makes the outside housing turn left to right hence advancing and retarding timing.
I wish i took some pics before i turfed it, it would help it make more sense.
Don't press one apart if it's still needed for use because doing so destroys it enough that it's junk, they're only designed to go together once.
You need a lot of processing power. Pretty sure some BMW engines have infinitely variable cam timing for each individual cylinder. VANOS or VARIOCAM or something like that if I recall.
Ford DOHC sixes have dual VCT now, but its not of the same complexity as the BMW system. Apparently VCT was the main culprit for the gain in power those engines gained from AU to BA because it extended torque higher in the rev range.
Prolly not likely to happen for an RB25. Still, fixed is better than nothing!!
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
