PARTING OUT SOME OF THE STUFF IN MY GARAGE
4* 18' RIMS (2 WHITE . 2 GOLD)
2*18' ENKEI RIMS (1 HAS A LARGE DINT)
R13 RUBBER NEAR FULL TREAD
2 RB25 HEAD COVERS
1 LARGE CALIBRE TACHO WITH SHIFT LIGHT
1 DAMAGED LHS R33 S1 HEADLIGHT (CRACK IN COVER)
1 STOCK VZ EXHAUST
OPEN TO OFFERS SO THROW THEM AT ME PEOPLE!!
CHEERS
ANDREW
https://www.sau.com.au/forums/topic/343912-r33-parts/
no intention of buying your rims unless ur willing to swap for my coin jar with coins but it might help if you put up sizes
im sorry that u cant see the sizes....
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5544558
As per the For Sale Thread rules you need to put prices for everything. Otherwise members, just like the ones above are going to keep asking you!!
im not sure how to edit this:/
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5545740
4* 18' RIMS (2 WHITE . 2 GOLD) $1500
2*18' ENKEI RIMS (1 HAS A LARGE DINT) $300
R13 RUBBER NEAR FULL TREAD $50
2 RB25 HEAD COVERS $50
1 LARGE CALIBRE TACHO WITH SHIFT LIGHT $200
1 DAMAGED LHS R33 S1 HEADLIGHT (CRACK IN COVER) $100
1 STOCK VZ EXHAUST $300
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5545742
so 18x8 +10 so they will fit my car perfect or is it +40 to fit a subaru perfect
dunno man
i dont kno much bout rims
i took a pic of inside the rims so ....
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5546133
he cant be serious? for that pile of junk ? lawl
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5547843
2 RB25 HEAD COVERS
1 STOCK VZ EXHAUST
CHEERS
ANDREW
PM Sent
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5548304
Grab a tape measure out and see how many inches they are wide to start, and on the back see if there is a +(number goes here).
Also that one you took the photo of is actually 17x8 +38. Might want to edit the items :D
yea enkei are 17's.. my bad
https://www.sau.com.au/forums/topic/343912-r33-parts/#findComment-5550998
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
