VG30DET Ball Bearing Turbo, actuator included, This turbo is from a single turbo 3.0L Nissan motor its much bigger than a turbo from a 300zx which is a vg30dett. Turbo has been checked out by garret and is still in good condition also comes with a high flowed front comp cover, rear back plate and a T04 Comp wheel, all ready to be bolted on. Asking $600 ono for the lot cheers
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/
  • Replies 40
I wouldn't say its a bolt on turbo unless the snout has been modified.
Basically the VG30 snout (compressed ait outlet) is dead straight. The RB20/25's require that the snout first go straight then do a 90degree bend, it then attaches to the IC piping. I poped down to AAA exhaust and had them make up a 90degree 2.5" bend. You are unable to use the RB20/25 turbo snout as it is smaller in diamater. I can't remember if it bolts up or not though. I bought mine for $600, went through 2 turbo's from the same jap importers. Both were stuffed. :rofl: Something to do with how they spray the crates hence moisture gets in to the bearings and rusts them.
ALso.. the VG30 Ball bearing turbo's came from the Infinity/Leopard VG30DET that made 190kw at the flywheel. Not the VG30ET from the old 300zx. Those turbo's are non-BB.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699491
I took the turbo to two places, honeywell garret and j.c diesel which also repair turbos. Both comp-anys told me it was in good working order and it is a ball bearing item. In standard form is only good for 1bar maximum. Before i bought this turbo i rang at least 12 different places and only 2 places had one in stock. I got quoted $550 at one place and $770 at another. Some guy from this forum was going to sell me one for $900. As for documentation does it realy matter? it is a second hand item im selling and i have had it checked out by two different places. Price still stands at $500
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699850
GTST,
The oil & water lines don't have to be modifed IF the turbo is Ball Bearing.
There is one oil line that feeds in from the top of the turbo and a water line that feeds in to the turbo from the side of which the block is (its a bastard to do up as well).
Use the lines from your old RB turbo. Bolt up perfectly. As I said before the 'only' thing that has to be modified is the compressor's outlet so that it mates up with the IC piping.
Is there any chance of a pic from above to view the core? (inbetween compressor & exhaust wheel)
$500 is around the price peoples.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699997
I had a look at the turbo and it does have an oil feed from the top etc. I know the series 1 rb25 turbo has 45v2 on the front cover. The main advantage of this turbo over the standard rb25 is that it has a slightly bigger ration on the exhaust housing, the guy at garret confirmed that for me. Thank you very much Joel for backing me up on price.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-700533
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
