VG30DET Ball Bearing Turbo, actuator included, This turbo is from a single turbo 3.0L Nissan motor its much bigger than a turbo from a 300zx which is a vg30dett. Turbo has been checked out by garret and is still in good condition also comes with a high flowed front comp cover, rear back plate and a T04 Comp wheel, all ready to be bolted on. Asking $600 ono for the lot cheers
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/
  • Replies 40
I wouldn't say its a bolt on turbo unless the snout has been modified.
Basically the VG30 snout (compressed ait outlet) is dead straight. The RB20/25's require that the snout first go straight then do a 90degree bend, it then attaches to the IC piping. I poped down to AAA exhaust and had them make up a 90degree 2.5" bend. You are unable to use the RB20/25 turbo snout as it is smaller in diamater. I can't remember if it bolts up or not though. I bought mine for $600, went through 2 turbo's from the same jap importers. Both were stuffed. :rofl: Something to do with how they spray the crates hence moisture gets in to the bearings and rusts them.
ALso.. the VG30 Ball bearing turbo's came from the Infinity/Leopard VG30DET that made 190kw at the flywheel. Not the VG30ET from the old 300zx. Those turbo's are non-BB.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699491
I took the turbo to two places, honeywell garret and j.c diesel which also repair turbos. Both comp-anys told me it was in good working order and it is a ball bearing item. In standard form is only good for 1bar maximum. Before i bought this turbo i rang at least 12 different places and only 2 places had one in stock. I got quoted $550 at one place and $770 at another. Some guy from this forum was going to sell me one for $900. As for documentation does it realy matter? it is a second hand item im selling and i have had it checked out by two different places. Price still stands at $500
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699850
GTST,
The oil & water lines don't have to be modifed IF the turbo is Ball Bearing.
There is one oil line that feeds in from the top of the turbo and a water line that feeds in to the turbo from the side of which the block is (its a bastard to do up as well).
Use the lines from your old RB turbo. Bolt up perfectly. As I said before the 'only' thing that has to be modified is the compressor's outlet so that it mates up with the IC piping.
Is there any chance of a pic from above to view the core? (inbetween compressor & exhaust wheel)
$500 is around the price peoples.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-699997
I had a look at the turbo and it does have an oil feed from the top etc. I know the series 1 rb25 turbo has 45v2 on the front cover. The main advantage of this turbo over the standard rb25 is that it has a slightly bigger ration on the exhaust housing, the guy at garret confirmed that for me. Thank you very much Joel for backing me up on price.
https://www.sau.com.au/forums/topic/34394-vg30-bb-turbo/#findComment-700533
