Ok its time to part out my drift project that almost made it but has to makr room for a house. I am open to REASONABLE offers on all things.
- Pintara gxe shell with REG till March 2011, series 3 fromt end, series 3 tail lights, sound deading removed, BRAND NEW battery mounted in boot and wired up, slight damage to left hand sill
price $200
- 4x114.3, 25mm x 2 bolt on spacers
Price $125
- Monza Evo fixed back race seat on r31 rail
$110
- Brand new HSD HR s13 coil overs, modded to fit straight in to diff (still have to drill rear shock tower) 10kg front and 8gk rear spring rate
Price $1400 (cost me $1600 a couple of months ago)
- S13 front controll arms with uprights and brakes (pads and disks)
Price $180
- barnd new Microtech Lt10s with x4 ignition box and 4 x coils
Price 1200 (microtech cost me $1300 and coils cost me $200)
- Ca18de package , has turbo manifold (T3 flange), oil return pipe in sump, Ca18det injectors, BRAND NEW exedy clutch, Recoed Altinator, ca18DET gear box, cutom gear box mount, urethane engine mount, Brand New NGK Iridium plugs,
Price $850 (Clutch cost me $750, alt cost $120 to reco, urethane mounts cost $80, you do the math)
- S13 turbo box with Ca18det bell housing
Price $180
- 11 x stock steel rims with 185/75 r14 tyres,8 are road worthy.
Price $100 (thats less than $10 a wheel and tyre)
- 2 x 235/45 r17 bridgestone potenza tyres a little camber ware but above indicators
price $65
- 2 x 235/45 r17 mixed tyres just above indicators
price $35
- 2 x Rays tag rurher rims 17" x 9" with 80% tyres
price $350
- 4 x enki rims 17"x8" and 17"x7" with 235 and 215 tyres about 60% tread left
Price $750
-New bosch 044 external pump (has only been installed)
Price $150
-New in tank VL lift pump (has only been installed)
Price $100
- 1lt stainless steel surge tank
Price $180
- s13 ca18 brake master
Price $50
- s13 ca18 brake booster
Price $30
- s13 ca18 power steering pump
Price $30
- Random front strut brace
Price $30
- S14 standard exhaust dump pipe back
Price $30
- s14 standard side mount intercooler
Price $40
- 2x 17x8 rims, rubber is only good for skids, 5 x 120.4 commmodore/bmw stud pattern
https://www.sau.com.au/forums/topic/343963-parting-out-my-drift-car-melbourne/
hey nath I am in Ferntree Gully, melbourne. coil pack and loom is for sale with the microtech and the inlet manifold is for sale with the engine. the cooler and turbo setup is not for sale as I am keeping it.
There is a pic up of the intercooler, that's all...
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
