an atmo bov is also more likely to make an auto stall as the gears are not constantly meshed (same reason you can't push start an auto)
who fed you that line?
anyway, it will give you no advantages over your stock BOV other than sound.
i have a GReddy plumbed back and it is plenty loud enough.
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5545637
atmo bov = really rich on bov vent
manual box = gears constantly meshed, clutch in revs drop, clutch out brings revs back up
auto box = lift off for bov to vent, back on the gas, car is over fueled to bov release, stall out and fail
doesn't always happen but quite often will
if it doesn't, you will get black smoke on bov activation and you'll get a dirty rear bumper
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5545738
Smokey he's correct aftermarket BOV on an auto increases stalling and car running shit at low speeds. Why do you think certain controls are on airflow computers for if you have a BOV installed it adjusts voltages on sudden throttle let of to decrease the chance of stalling.
Of course it will give him gains over stock that's not just sound improvement. It will hold boost stronger that the stock oem Nissan jobby made for 7psi with a 10+ year old spring in it.
-1 for incorrect technical advice on forums.
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5545890
the driveline is always engaged in an auto, the momentum of the drivetrain keeps the engine turning over - it won't stall. it might overfuel, but it won't be any worse than on a manual which drops revs dramatically when you snap throttle shut and clutch out which drops revs to idle speed within a matter of milliseconds.
i dont disagree that atmospheric BOV's cause spikes in AFM readings - i have always run plumb backs. my disagreement was that 'they are more likely to make an auto stall'
not withstanding the fact, that i you read his statement closely, he says 'because the gears are not constantly meshed'.......which is the exact opposite of how an automatic transmission works anyway. the car is in D - the gears are engaged with the torque converter acting as cushion.
and there is nothing wrong with the stock bosch BOV's from nissan. i had twin bosch GT-R bov's setup on my 30ET - which are proven to hold 32psi and nearly20 years old. proven performers.
so you keep your 'technical advice' scorecard, i'll keep mine. :blush:
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5545988
sorry but auto's are complete p1gs to drive with an atmo or even no bov when compared to a manual. its not the high rpm changes that are the problem, its when you back off at low rpm, say under 3k, that the stall convertor lets the rpm drop back to idle speed making it easier for the engine to stall. at least with a manual you can let the revs run down slowly with the gears when you back off, or give it a quick kick in the guts to stop it stalling without the car lunging forward.
i know this from personal experience of having to put up with no bov on my car for a couple of months after i did my turbo upgrade until i sorted out a replacement. only reason i was running no bov was the stock stagea bov, which in my opinion is complete rubbish for anything other than stockish sort of boost pressure, couldn't even hold 14psi.
the first time it stalled on me was at a really really bad time, turning right across a busy intersection, i accelerate quickly, but not going over 3000rpm, and back off as i'm at my desired turning speed, car stalls halfway into the intersection, then the mad panic to get going again. this is how it was:
car stalled --> f**k --> steering too heavy cant finish turn, f**k --> turn key to crank engine again, hang on, it wont start, f**k, panic --> oohhh, its gotta be in park or neutral to start (this is the last thing on your mind when you stuck in the middle of a busy intersection)
after that i found myself sometimes riding the brake and accelerator to keep the revs up and prevent a stall. a manual would have been instinctually easier to restart after a stall, car stalled --> clutch in turn key and off we go.
edit: to the OP, if your car is an auto, weather it be S1 or S2 it will have a bov, if you have a stock airbox it will muffle out the sound of the release and you will hardly hear it. but dont worry, it will be there.
Edited by QWK32
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5546439
^^^ I get the same problem across intersections when you stop at the island.
I don't run a bov because I'm too lazy to source a GTR item, so I need to heel-toe to blip the revs back up so it doesn't die.
Edit: I have an auto.
Edited by d1_drifter
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5546464
wait, just let me get one thing clear, the stock BOV is not atmospheric, but rather flows back to turbo right????
so even if it only holds 7psi or 15psi etc. doesent it mean your air still gets to run at 7/15 psi??? since it just sends it back to its original starting place????
not like atmospheric where that certain pressure is lost and vented to air?
kinda hard for me to explain without a diagram.
but basically even with a stock BOV you wouldnt have any power loss what so ever since it just circulates the air???
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5546690
it is released into the intake just before the turbo compressor inlet. it dumps the pressure from the turbo compressor outlet side.
https://www.sau.com.au/forums/topic/344016-blow-off-valve/#findComment-5546707
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
