on an r33 gtst, the crossover pipe and intercooler piping for a fmic gets pretty farking hot after driving, so all the work the intercooler is doing is just being canceled out from the hot pipes in the engine bay, is it worth wrapping the intake piping in the engine bay including the crossover pipe in insulation tape to block out some heat?
https://www.sau.com.au/forums/topic/344039-insulating-the-crossover-pipe/
The intercooler is a heat exchanger, not a radiator.
The heat only transfers from the pipe/cooler into the air stream when you decel or idle. Almost the instant you mash the throttle the cool air coming from the intercooler is able to enter the engine without absorbing too much heat.
If you were to HPC coat the inside and out, I'm sure you might get a small advantage but the cost would far outweigh the advantages
The intercooler is a heat exchanger. As is the radiator.
The point is that the amount of heat the turbo puts into the compressed air (Which is a measure of its inefficiency) is alot less at lower throttle openings than at WOT. So there is less heat to be removed at low power levels rather than the inter cooling being less able to remove it.
The point is that the amount of heat transferred to the pipe section per lb of air (or however you like to measure your air) is negligible. Hence it is not worth bothering insulating the pipe.
Or in other words.
No.
EH???
lunch time brain fart and I still can't think of the correct word.
Radiators are also a type of heat exchanger but what I am trying to say is that the intercooler will absorb heat from the charge air on acceleration, then on decel a lot of that heat will be put back into the air stream. If you hook up temp sensors and monitor before and after you will see what I am talking about
"Heat sink" the two elusive words??
  • 2 months later...
I have recently tried this and there is a slight noticeable difference. On paper people may disagree, however i noticed it. I almost went for a turn flow intercooler for this reason. I used some heat reflective shining tape from bunning's and wrapped it around twice and then back along that whole tube. I swear it made a difference and the engine feels a tiny bit more punchy. ( wild guess and i would say 1 - 2 kw @ wheels ) i tried it on the same day in similar temperatures as well. I am just an amateur though but thought i would comment
glad i did it.
The heat on Decel would be due to the lack of flow through the system into the engine due to the throttle body being closed? And I guess without flow the air will will absorb heat from engine, pipes etc.
Something I've never really thought about till now
Just doing some more research. found a guy who has measured the difference in temperature
7 - 10 degrees ( don't know what car though but it says the return pipe goes over the radiator like aftermarket gts-t - gtt FMIC kit )
Does anyone agree that even a drop in 5 degree might get you 1 - 2 kw for all the non believers
using oven mitts ?
Insulating the Return
In that article the guy says that his intercooler exit temperature is almost ambient, so he has optimised for the condition when the turbo is doing next to nothing. If he were to try again with a turbo running hard (so the compressor is adding heat) then he would find that insulating the pipe is a backwards step (assuming underbonnet temperatures are less than compressed air temperatures). But yeah, probably doesnt make much difference either way, as sections of pipe are not great heat exchangers.
Djr has it right, the answer is
No
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
