Recently bought a set of work xd9s in 18x10 with a +18 offset. They havent been fitted to the car yet as its still in peices and waiting for paint. What i need to know is do these go on with out any mods, and will i need to stretch tyres maybe?
https://www.sau.com.au/forums/topic/344067-work-xd9-18x10-18-r32-gtr-users/
  mattyneweraimports said:
33 and 34 should be ok
not sure about a 32, think your going to have a little bit of an issue
thats the same offset /size 18/10/18 as i had on my NTO3s on the 34
why dont you just test fit one?
i havent ordered any tyres for it yet, i test fitted them on with the car off the ground, sticks out the guards a little, but i spose the car was unladen. Ive seen a few r32 gtrs with the same sized wheels, but unsure if any mods where done to get them on there
I had them on my 32 gtr with 235 tyres, only cuz that is what you could legally run on them in QLD and they stuck out 5-7 mm on standard suspension. So with some 265's and some lower suspension you should get away without flaring the guards, that if the guards havent been repaired for some reason in the past.
I'm in the same position at the moment with XD9's and looking at using a 265/35, would prefer not to roll the guards..
Here's a few from rimtuck.com without guard mods.
18x10+16 with a 275/35, -3 front camber and -1.5 rear camber and no guard mods.
http://www.rimtuck.com/setup.php?id=325
18x10+20 with a 265/35, -1.5 and -2 camber and no guard mods.
http://www.rimtuck.com/setup.php?id=322
When I first bought the car it had r34 gt-r rims with a 275/35, was going to add a 10mm spacer all round and it would of just cleared the guards. I checked the XD9's with a 265/35 against the old rims on a fitment calculator and it said the only difference is that the XD9's will stick out 7mm more.. I'm going to trial fit a tyre just to be safe before I buy a set anyway.
Here's the calculator
http://www.rimsntires.com/rt_specs.jsp?item=Wheel-Tire
I run 263/35/18s on my XD9s the same size. You will need to get your guards rolled. I had them without the guards rolled and standard suspension and they used to scrub in the rears. Rolled guards and stiffer suspension has sorted out all my scrubbing issues.
  Deano 1 said:
im runing same wheel with 245/35/18 my gaurds are rolled, no clearance issues at all, goin to go 255 or 265 for my next set.
Is that both front and rear guards rolled? or did you get away with just rolling the rears?
i got 18*9 + 15's on my r32 gtr and i needed to trip the inner guard liners on the front and i need to roll the guards on the rear and i am running 245 wide tyres with a 35 profile
