Hi guys,
I seam to be having a missfire or missfire like problem with my r33...
now before someone posts up reply to search missfire i already have and nothing relates to my issue
what seams to be happening is when its warmer weather the car runs really nicely doesnt skip a beat but as soon as it cools down just a bit it starts to splutter on and off through the revs and sometimes if i dont back off spltters till redline its very similar to a screwed coilpack problem but from what i gather why would the coil pack work in warm weather but not in cold.. also i just recently changed all my spark plugs and sealed up the coilpacks with high temp silicone to stop the spark jumping and hitting the head i cant see it being a fuel issue for the same reason the only thing i can think it could be is the AFM would this cause this type of problem?
current mods are:
3inch turbo back exhaust
podfilter/cold air intake
front mount
boost tap
boosting at 10psi ATM have kept a close eye on the boost in difrent weather conditions and it stays at 10psi in cold and warm weather so its not were near hitting the boost cut or spiking
any help would be greatley apreciated lost for ideas
Cold air is denser than warm air and therefore containers more oxygen. This makes your car perform better (hence why your car pulls better during the night compared to during the day).
This increase in oxygen is obviously enough to get past the threshold of your ignition system.
This is probably the most common problem on Skylines due to coilpacks that are getting old. Putting silicone on them does nothing to help them if the problem is internal.
What spark plugs have you got in there? If you have a 1.1mm gap you should go down to a 0.8mm gap and that shall solve your problem.
If you are allready running a 0.8mm gap than your coilpacks will need changing. This is why you see nearly every Skyline running Splitfire coilpacks (they are cheaper than brand new OEM ones).
Edited by PM-R33
I don't think the boost tap is causing any problems like I said when I say cold it's not freezing weather it's just cool when it's a 30 degree day it runs fine yet when it drops down to bout 25 it start and the more it drops the more it does it I had iridiums in it and was told by a Mechanic to change them to standard ones I'm not sure what the standard gap is.. I never gapes when I put them in I don't have a vac leak because the boost gauge sits on -20 when the car idles which from what I know is good
OwSo I should have it suckin in the air from the engine bay ? What.would be.the proper.way to fix.this.? This did.start happening.since I put the pod and cold air.intake on it I ran a peice of intercooler pipeing from wherr the.stick intercoolet used.to come back and made a box for the filter
This will also max out the standard airflow meter because of the cold air coming in through your air box. This will cause the ecu safeguard 'rich & retard', which enriches fuel mixtures and retards the ignition timing in an attempt to safely reduce the amount of boost the thing is making. 10psi in the day and 10psi at night are two different thing because the air is more dense at night and the AFM recognises this hence R&R.
This same thing happened to me when I fit my FMIC and CAI. I had to immediately block my massive (bout 5") cai just so i could drive it up the road and back.
If you can, fit the standard air box with panel filter or
get a mines or equivalent standard ecu with boost cut, rev limit, R&R etc. all removed or
get an Apexi AFC or
get nistune or
just fork out and get a complete after market ECU... like what you should have done first if you had plans to get any more than standard power...... just as I learnt the hard way :P
But seriously, just test it tonight by blocking it off and go for a blat.
EDIT: Because you have a FMIC you shouldn't have any intake temp. problems with the CAI blocked off.
Edited by RBceffy25
Thanx guys really appreciate the help going to put the stock airbox in today and see over the next few days when it cools down see if it makes a difference.. I've already cleaned the Afm a few weeks ago with circuit cleaner didn't make any diffrence!
changed it back to the airbox today took it for a spin tonight and ended up being alot worse than it was with the pod!.. i starting to beleve this would be a faulty AFM
can any 1 suggest good skyline mecanic workshops which i could take this problem to... im in the sydney area dont mind traveling a bit
Try gapping your plugs to 0.7 mm. I had major misfiring problems as well when I put a turbo on my 25DE and I brought the car back to my tuner and he said gap them plugs to 0.7 mm from 0.8 mm and it should be mint. Never had a problem since. Still amazed how much 0.1 mm made a difference because my misfire was reaalllly bad before.
Edited by mjscar
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
