  • Replies 55
Ok, So far we have 3 people, dont we?
SkylineDave = K578M865 $1000
Mesmer = K578M865??? (Or not involved anymore?) $1000
Mesmers freind SR20 Kit = K557M865 $950
If you guys are definate, please send me a email to [email protected] with the following details:
Name:
Address:
State:
Post Code:
Contact number:
Kit Number Requierd:
I want to try and organise the cut-off date for end of this week (Friday) if possable.
Cheers,
Trev
Hi Inasnt,
Havent seen you for a while!? ;)
Naa cant get rods just yet, I might organise a group buy of Pauter Rods later on this month though... so i will keep you posted.
Also i will be organising this group to end on friday.
only Dave has responded so far, if theres anyone else drop me a email.
Cheers,
Trev
Around 2 weeks...And just for piece of mind, i track the parcel a week after it has left just to be sure everything is on track. (And notify you guys)
If Dave is happy to wait around until your ready, thats fine by me...?
Perhapes you guys can work a date out, and get back to me.
Cheers,
Trev
Hey Im after a set of forgies for my Rb30/25 conversion whats happening with the order. Let me know. Ive been in touch with the people at rocket who stock the Aries forged pistons and they need both hands to find their own asses. I spoke to three different guys and got three different prices from $1047 to $1205 and they said theyed be in next week , early April maybe ??? Making further enquires the Aries pistons tend to have failure problems after 24 lbs boost ??? Jnr24 what kind of rings do the Weiscos come with are the ductile iron or chromemolly ? Im pretty keen to move on these if they are the right ones as my Rb 25 is on it s last legs. I got just about every thing else ready to go and the pistons are holding me up !
Thanks Dude
Ok All,
Cut-off date is this coming FRIDAY (19th of March) if you are unavialable to make this buy then you will have to buy individualy. Please respond ASAP, the AUD vs USD has changed heapes since my last post and i have to advise of any new price changes. (If there is any, this will be determined, by the amount of people that buy, rates, shipping cost etc...)
For all that can make this date you must Have the money Xferd over by friday the latest. please send me a email with the following details:
NAME:
ADDRESS:
STATE:
POST CODE:
CONTACT NUMBER:
WISECO KIT NUMBER YOU REQUIER:
On thursday i will post the final price for all involved in the group buy.
Cheers,
Trev
Trev;
Ive noticed some discrepencies in the Wiseco cattle dog In the Rb30 section the rod length in inches is wrong(if you divide the mm rod length into inches you get a different number) But the most concerning thing is in the Rb 25 section where the dome volume is stated as 14(I assume cc's) but if you look at the note at the extreme right the kit number is coded with a 1,2 notes number. If you go to the very bottom of the page you'll see the 1 coding is of not much concern but the 2 coding states that the piston is a flatop with no flycuts for the valves???? That aint gonna work. Any chance you can email them for clarifcation ?
Let us know
Peter
Hey Peter,
My engine builder has built a few of these RB30DET's using the wiseco RB25DET pistons (K578M865) is the kit number.
The last engine he built made 470hp@wheels with a GT30 turbo. To me it looks like they work :P
-Dave-
Dave your alive! :P
Allthough he has used these pistons in a RB30, did it have a RB25 head?
If you dont mind me asking, can you PM me you engine builders number? I just need to talk to someone who has used these pistons.
P.S Are you in for this friday?
Cheers dave,
Trev
Guest
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
