Just was looking at the Garrett website and noticed they have put up some new part numbers!
Wonder what pricing will be?!?
Those compressor maps look impressive for big boost and power (should go great with E85!)
Edited by SimonR32
https://www.sau.com.au/forums/topic/344089-garrett-medium-frame-gtx-turbos/
Oooo the 3071 looks brilliant in terms of a good RB25 upgrade/stock motor
GT3076 is very interesting too.
GT35 just gets fatter, almost 10lb/min :dry:
That would be a very good upgrade.
But indeed... all comes down to the price lol.
Interesting if they get some 2860 graphs up.
Found this interesting bit of text on a website selling these turbos.
"This is the new Billet version of the previous Garrett GT3076R model.This Dual Ball Bearing turbo has an Oil & Water Cooled center cartridge. This turbocharger is on track to replaced the older GT3582R model as the most popular mid sized turbo on the market. The original GT3076R paved the way for many performance enthusiasts earning its place as the best all around turbo out there for most peoples needs. The new GTX3076R makes more power, spools faster, and is all around better than the GT3076R."
http://realstreetperformance.com/store/57m...turbo-2009.html
So does this mean that your basically in a gtx3071r youll be getting more power than a 3076 and less lag and with the gtx 3076r youll be getting power like a 3582 with the response of a 3076?
as far as the comp maps show there it will be very close, the gtx3071 map is almost spot on the normal 3076 so they will make similar power but the normal 3582 map still flows a few more pounds/Min more than the GTX3076
Well aslong as gtx3076 makes more power than before without added lag then I think I found my next turbo.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
