A few places sell GTX3076R without turbine housings, at which point they are the same price as a "full" GT3076R... be careful that you dont end up with a full turbo.
Yeah I know, but this was on gcg its bout 1750 for the gt3076 ext and 1300 for the gtx3076 without housing plus antoher 550 for ext housing so its about the same. I find it odd.
gt3076r is $1099 without exh housing get your facts right.
Calm down mate, your right about the price.. 500+ for the 4 bolt or 700+ for the v band housings is an outright rip though.. The internal gate price and the price for the actuator is a joke also.
Hrmm just checked and yeah saw that one but why is the this other one the 52T $1732?
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=233&category_id=28&option=com_virtuemart&Itemid=101
I must be missing something just cant pick it up lol.
is it just the blade design that has changed? reading this part "Outline interchangeable with Garrett® GT Series turbos" it makes it seem like i could just buy the better blades that fit my turbo for a cheaper upgrade.
Not on the compressor side, but any gt30 rear will fit on the GTX as they haven't changed the turbine wheel.
There are billet compressor wheels on ebay for the gt30, not sure how good they are but you would need to get it balanced by Garrett after fitting it.
My Proflow fittings were weeping ethanol. The rep is looking at them now. I cant fit the turbo until thats sorted unfortunately. Funny enough, the "Torques" ebay fittings were perfect, tested to 90psi as thats all the reg can do.
The other issue I had, there is a large anti surge cup in the fuel tank with small slots in the bottom, at under 1/4 tank the twin walbros can empty it in a few seconds so I need to enlarge the holes. Im back on the stock fuel system for a week or two. (Lucky I left the stock lines in)
  • 3 weeks later...
Got mine back. Gtx3076. Laggier than stock. Duh. Nice power curve 272.9rwkw at 17psi I think they said. Only got power/torque chart. Getting boost chart tommorow.
No internals. This a daily safe tune.
Mods? Keen to see the dyno sheet :)
That sounds like a normal GT3076 that kind of power, keen to see the dyno sheet to see how much laggier it is compared to a GT3076
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
