Garrett Medium Frame Gtx Turbos
SimonR32
It was more of a "that's the way the turbo s, we will see if can gears help. But it wont shave too much" can sub par actuators display issues like I'm seeing? Lazy boost response etc?
If you are in VIC go see STATUS, he will sort you out.
I know all dynos are different. But it FEELS like.it builds and should be coming in like 500 or so rpm less. I know the.guys at avo very well. On a personal level. And they wouldn't intentionally take me.for a ride. I might have a chat to status. Because I don't want my dyno sheet to look nice. I want it to FEEL better driving. Avo can make my synopsis look.nice if they want as you all know just fiddling with ramp rates etc.
I had a thought regarding this - ShiftTys, how does the car actually drive from your perspective? Does it seem that laggy?? If you put it in 4th at say 2500rpm and floor it, what rpm does it reach say 7psi, then 15psi (if its not too dangerous to do that)?
Were you present for any of the dyno runs? Looking at those plots, it makes me wonder if there was a very quick sweep rate used - like 6s or quicker for a run? Thats potentially too quick to give an equal comparison to most dyno plots out there, and potentially too quick to replicate what you might experience in the real world.
I'm.bout to drive it. Dyno was done in 3rd. Should.I try 3rd?
Ok. 3rd. Foot to floor from 2500. 5psi at approximately 3100. 10psi at approximately 35-3600. Didn't go further. This is according to my gizzmo. Hmm. very different to what dyno says.
That sounds better... to explain what I mean, it doesn't matter really what gear the dyno is done in - what matters is how fast the dyno allows the car to go through the rev range. The more time the car spends going through the rpm, the more time the turbo gets time to build boost.
If they have a 6 second sweep starting from 2000rpm to 7500rpm it might be a bit more like starting in 2nd gear, if they have a 14second one it might be more like doing it in 4th - just plucking numbers off the top of my head to explain what I mean.
Here's a video I made ages ago of a normal GT3076R .82a/r with internal gate back before my car was fully tuned, maybe try and compare the same kinds of pulls with your own to get an idea:
I would expect it to be SIMILAR (give or take) to what I had there, if its substantially laggier than that then I'd be looking at the overall setup.
I'd expect in 4th gear you should be able to make full boost by 4000rpm on the road. If that all works, there is no problem - the dyno run was probably done with a really fast sweep and will make any car on it look laggier than you'd experience on the road, and also a pretty unflattering impression of how the car goes relative to others. Perfect example of how dyno plots are only part of the picture...
So if I'm hitting say 17 or so psi by say 4100. That would be reasonable?
17psi by 4100rpm in 4th? In 4th thats not as bad as the dyno looks but not that flash imho, in 3rd I would say reasonable. Do you have VCT engaging? When does it reach 14psi? (to rule out a lazy actuator)
It looks reasonable to me for a 640hp capable turbo. I doubt you would get a GT35 on boost that early. I just think you are strangling the exhaust with the small housing, I would have gone the .82 or bigger with an external gate. Its like putting a .63 rear on a GT35, its no good for top end so why go so big in the first place.
Not to me - My GT3076, made 18psi at 3100rpm, on a rock stock RB25.
Dude! Please read my comment above.
Get Trent tohave a look mate... A second opinion never hurts
Please do this before you go changing the turbo, it will only cost you about $100. f**k, I'll donate $10 to the cause, just because I want to know if these turbos really are lazy. Is money an issue? I'm sure others will help. I'm willing to help out this time around.
Please be smart about this and make sure you are 100% certain its the turbo.
Edited by The Mafia
I've already sent Trent a text. Waiting for a reply. What so max boost in 3rd. By just over 4k is.not bad? Ill Suss on the streets later.
I do have. 82......
Is it only running a .63 hotside? Fwiw I've been in an R33 running a .82a/r GT3582R which would reach 20psi by ~4300rpm...
Running. 82 NOT. 63
I will get Trent to look at it. Money is an issue. It.cost me.a.bit to get this all set up as it is.
As per my video I posted, mine is 15psi by around 3800rpm in 3rd or by 3500rpm in 4th so it makes it maybe slightly laggier than an equivalent GT3076R which isn't too surprising
I'm merging them. Makes it far easier to follow/read, dw about it.
Was gonna say that is an AWESOMEA FORUM FEATURE! automated msg combining. Lol
Ok well ill see where my Max boost hits.
I do have. 82......
Running. 82 NOT. 63
Everyone, I am interested in seeing if this turbo really is a bit of a lag monster, or this fella has just set it up wrong. I am willing to put in $10 towards his dyno time with Trent.
If we do this properly, I'll gather the cash and send it directly to where he takes it (Trent from Mercury, or am I on another planet?) This way, its fairly legit. Plus, I ran a $5k group buy a few years back, and made a lot of friends, so you can trust me. Plus, its only about $100 or so.
Anyway, I am happy tpo help out. Its also going to save me thousands if I decide to take a risk and end up buying a turbo that is laggy, or not suitable for me.
Anyone keen in helping out this test?
If we go ahead, I want to know A LOT of info about your car mate so Fill in this form for me:
Engine:
Intake Manifold:
Exhaust Manifolf:
Cams:
Compression Test:
Fuel:
Intercooler Size:
Pre intercooler piping size:
Post intercooler piping size:
Full exhaust specs:
Dyno Chart with AFRs plotted:
Full Ignition Map:
Base timing:
Type of ECU:
Anything else I Can think of over the next couple of days
I know thats a lot, and maybe it will take you a while to get the ignition timing down, but hey, if you want a pretty much free diagnosis, work for it, haha.
Fill this out please.
I really want to see this turbo tested properly. I cannot recommend it to people (I'm a tuner, and I get a lot of people asking me what they should buy) if its not what garrett claims.
Thanks, and I hope people are interested.
Edited by The Mafia
    • This is a simple swap when you reuse the RB20 loom and auxiliaries. I run a standalone, but if I remember right, using the RB25 ecu you only have 2 injectors to inverse.  There are many DIY's on this subject online, including this forum.
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
