http://www.skylinesa...5890781__st__20
almost 1000rpm of spool difference, although completely different dyno setups so not really that compareable. Still it really does look like his is set up perfectly.
He is also using external gate and manifold, what are you using?
Internal gat and no manifold. I get full boost by about 4k on Trent's dyno. Forget the other chart. Ill post up Trent's one asap.
Gives me hopes to see the gtx spool faster than gt. Means ill have same/more top end with better spool.
Edited by ShiftyTys
4K actually sounds around about what I would have expected for that setup, thats not too bad.
Trent recons a bit of a fiddle n we can knock 500 Ish off. And give me another 20+ throughout midrange.
this is probably stupid but could t be the standard intercooler piping is also choking it..its only 60mm tube and that turbo is trying to push a large volume of air..also dont know what cat its running..still seems to me like its just choking up...im not convinced its just tune related :unsure:
Quite possibly but Trent recons mainly actuator based. I'm sure he would mention if it seemed to be choking at the cat or cooler. 3" highflowed cat.
Well he's got the advantage of having had it on his dyno and seeing where the potential is so thats pretty promising, I guess if VCT isn't (but can be) enabled there's definitely gains to be had just there. Sounds quite promising, and basically means GTX3076Rs will be full boost at ~3500rpm on RB25s which is pretty sweet.
Get rid of the cat.
How many people here that run this turbo are actually using a cat? or can say they have seen this turbo on a car with a cat? and are making a fair comparison on the response side of things. No cat will make a big difference
Edited by ido09s
id be getting a 80mm hotpipe and at least 70mm cold pipe made up as well.. PM scottynm35 hes near dandenong and will make that up for you.. He can probably gut your cat as well..
And get all this done before it goes to avo Monday week?
its a 3 inch cat on a 600hp capable turbo, of course its a restriction..
infact his whole setup is a restriction ....no offense shifty ;)
No.its not. Lol. At 600hp yes. But 3" Turbo Back is enough at this power surely The cat Is highflowed to 3" too. So id assume thats ok. I have 4" intake. That's fine. What else is.there?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
