How would a GTX3076 go with a 0.63 rear housing ( external) assuming it had either water/meth or E85??
assuming it had 22psi, would it be a fail or quite good?
Edited by SliverS2
You have the perfect housing, don't change it to the .63 or you will have more issues with det than you have now.
I doubt your engine is that coated in carbon that the compression would have been bumped, Can you get a scope down there for a look? If it is just drop the head off and clean it up, if its not there are some serious issues with your setup Mark.
Im starting to think its to do with the tuner, he didnt take very long, most of it was done within an hour, on the graph its only holding 16psi and you'd think he would of said, "mate, there only mild cams, you got some issues with leaks somwhere", it even stalled on him on the drive home, i think fix up this leak and possibly change the wastgate spring for a 1bar spring and even replace the resonator and then retune with E85.
My standard GT series made good power at only 21psi with .82 rear and full boost is 3800 or something.... So no need for smaller rear I don't think...
how long would it take to clean the motor if your running ethanol? or would that matter if your running ethanol?
Mine had a little carbon on the pistons, a quick squirt of gasket stripper cleaned them right up. Its a 150,000k engine so it should have been fairly caked.
The ethanol wont ever ping with a good tune and it's cheaper to run than 98 now the price dropped. (United) Shame the only outlet in Qld is Warwick, how close are you?
How well did it hold boost in the high rpm?
Did it drop off towards redline?
It used to drop off too 18psi by red line, tuner said if we could hold boost up top it would crack well into the 400's..
Warwick? im pretty sure theres some close by , well 40mins away at kessels rd mt gravatt which is on the way to the city anyway. :yes:
That would be from the pump, so is it right in saying the tuner will tune it not on the egde to account for if the ethanol content varies?
United is at Warwick.
Ethanol variation isn't a problem, even 10% variation would hardly change the afr's. I guess I have no worries with it as I bought a wideband, perhaps you should lash out $200 on a gauge too if you decide to go with e85?
Every tune is rich on boost, how much so depends on what your tuner is comfortable with. The Jap tuners love 10:1 on petrol with shitloads of timing, here around 12:1 and a less aggressive timing map is the norm. Either of these tunes should have enough overhead for a fair amount of variation and it should never ping anyway. Just make sure your tuner has e85 experience (although most would by now.)
I'm running 19-20:1 on cruise at the moment with no adverse effects, no knock and good exhaust temps. Try that with petrol, it wont run well and you would f*ck your engine fairly quickly I assume.
You need to get out more.
Caltex goodna
caltex springfield
caltex yamanto
Caltex goldcoast (suburb escapes me)
Caltex upper m Gravatt
All carry Eflex. I fill up at the yamanto outlet regularly and have used most of the others.
Plans are underway for a major increase in outlets, A new plant is being built in north qld right now.
Once completed you will see a major increase in the number of outlets.
any word if this major increase will stretch to NSW?
Nation wide from what I can glean.
The plant is definitely under construction as we speak. A friend has a supply contract for parts for the new truck fleet delivering cane to the plant when it opens.
That is freaking unreal. More or less the only issue I have with moving to ethanol is its availability.
If its more readily available in my area and on the way to wakefield I would happily retune my shitbox to run it.
Anyway, GTX bla bla bla.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
