I have seen the graphs, hopefully he will post them up soon. Split .82 rear with twin 40mm gates. Full boost by 3.5k sounds like a win for a 300kw turbo. :)
Wow, even with a free flowing exhaust mine would have been at best 3.7-3.8, TS makes a big difference :D
Yeh, I thought it'd be nice! Even if you lost 10-15kw worth of flow potential because of the twin scroll it'd still be worth it I think.
Awaits graphs...
Edit: is this the setup status was referring to in the 300kw unopened thread?
Edited by Mitcho_7
EPA test is tomorrow morning.. hope it passes....
im going to take the car there nice and warm so the exhaust cat's are heated up and expanded to capture all the crap..
anyone else know of any tricks? :P
I personally know of 4 RBs making over 400rwkw with stock bottom ends on E85, all driven very hard.
A nice safe tune on E85 and you shouldnt have a drama. Kinda makes built engines under this power a waste of money lol
Think i seen you last night going past caltex on canterbury rd around 930pm i was in the white r33.. you almost brought her on boost LOL
Didn't you just build your motor? haha
I'm with you though, if and when mine goes pop another stocker is going to be dropped into the whole and probably given more hurt than this one is copping :)
Ive had 3 built motors lol
At current Im not sure a stock bottom end would cope with 800hp to long.
Looks like its all going to plan Owen, cant wait for Ethanol results! It comes on a LOT harder/sooner than mine so the setup certainly works ;)
yeah, i absolutely love it! its actually a lot smoother to drive than i was expecting.
Big thanks to trent for the tuning!
e85 gear should arrive next week, then ill book it in for another tune! OH YEAH!
Ha! i was the same with mine, was amazed how smooth it is and its better as a daily than it was before...... E85 will be a serious kick in the pants though if your already getting those results :D Keep us updated as itll be awesome to see another one up and going!
thats a nice looking power curve, how come the torque curve doesnt hold a straight line? is it just different dyno's people are using or is the torque really dropping off
It's always going to drop off...
It's not a 800hp setup that makes all its power above 5000rpm
Not always, for instance these 2 cars almost don't drop any torque between 4000-7000rpm
Edited by SimonR32
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
