2 hours ago, Lithium said:
Nice!! Cheers for sharing :). More or less what one would expect, as you said.  A few hundred rpm laggier too by the looks?  And this would be on an RB30?
No problem.
Yeah I was hoping it wouldn't really loose anything down low but definitely did. However you wouldn't really know it to drive, and the plan was to try some E in it too.
Yes, 25 headed 30.
Really really interesting how much... Or little difference the  a/r change made.  Is this a divided setup?
And crikey - this looks like it's going to end up being a complete animal.
Yeah for sure. I started off with a .7 AR then .8x then 1 and came on earlier each time.
First time it has lost a little down low, but comes on hard!
Yes divided.
Nice, really interesting results overall.  What is the difference between the blue "E68" and the green "E68 boost earlier" curves?
655kw @ wheels isn't messing about at all, should be hell of a fast car there :)   The spool looks better than a few of the GTW results I've seen, quite cool to see a 25 head being used for something of this kind of power-  is it still VCT?
Blue had more WG duty from the start and really cold day.
Have not really seen any other results except I do have a GTW 3684 on a 25 I have graphs on.
Has everything there for VCT but not running currently, on my list.
Good power!  But yeah, solid point @Dose Pipe Sutututu - its what, 100kw at 4000rpm???  That is possibly the least power I've ever seen from an RB30DET at those rpm! :O
Edited by Lithium
  • Like 1
It's a dedicated drag car but running H-pattern for something a little different.
9.81 @ 142 with high 400s. New set-up should go a fair bit quicker.
More boost still to come. Plan is up to up it to around 40psi.
  • Like 2
Good power!  But yeah, solid point [mention=22311]Dose Pipe Sutututu[/mention] - its what, 100kw at 4000rpm???  That is possibly the least power I've ever seen from an RB30DET at those rpm! :O
Not a DET [emoji6]
See original post.
