Did someone mention earlier that MHI/Trust played with billet machined comp. wheels? Any more info on that?
http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/page__st__40
Basically based off post #58 on page 3.
Not exactly Hard info, but a reliable source.
Keeping in mind the new billet hype is based on different wheel technology. The new Garrett range has full blades, no half blades, and is a much deeper designed wheel than the cast items. It would only make sense that buying a 25g wheel in a different material would not boast necessarily insane results.
What would be interesting though is the 11 blade T67 turbine coupled with a GTX71 compressor ;) custom turbo anyone?
I think we both know the answer... nice one Trozzle :)
haha just checking...
He seems to spread retardedness over various threads :)
Some much more useful and promising results, a back to back test using a .82a/r GT3076R and .82 GTX3076R on the same car:
http://forums.nasioc...d.php?t=2110277
going by that thread it appears a tad lazier
http://forums.nasioc.com/forums/showthread.php?t=2110277
Nice results and back to back testing!!!
Really wish they would compare a X3071R to a 3076R, realistically the X3076R is only better on big boost (when loosing at compressor maps)
the difference is that small that you wouldnt notice the difference in response driving two identical cars bar the turbo change.
i would have to agree with disco after looking at their results for the 0.82 housing that for these new wheels to get the max out of them the 1.06 housing needs to be used.
looks completely negligible, the actual power and torque curves are almost on top of each other, it is only noticeable in the boost curve.
15-20hp is nothing to sneeze at, looks like a decent improvement for not much more.
Yup its decent and worth it if you are buying a new turbo, but not mind blowing like some people were saying.
The dyno doesn't tell everything about drivability and rolling response but it hardly looks like a major upgrade at this point.
GTX3071 is the one I want to see. The airflow map of that turbo looks like a real improvement.
do you think theres goin to be a chance of -5 wheels anytime soon..... it dosent sound like it,,,
Not soon enough for anyone looking to buy now I don't think
Still, even when/if they come out, it will take ages for a proper back to back test to happen so I'd say buy a set of normal ones and enjoy the use of them in the mean time
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
