http://cgi.ebay.com/ebaymotors/Garrett-GTX3071R-Turbo-T3-GT-internal-WG-Swingvalve-HSG-_W0QQcmdZViewItemQQhashZitem5880ad175bQQitemZ380115949403QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
So what would you turbo guru's predict this to max out at and how lazy would it be with a .82 rear?
looking at the compressor maps (which i still don't quite understand) would this made 300rwkw?
Well if the map is correct you can assume the compressor side of the TURBO should be good for ~ 540-550 Hp's worth of airflow at three bar absolute / 29.4 pounds psi gauge pressure .
This is not to say a Neo RB25 can do this because the map is only trying to show compressor end performance .
Since the flow ratings are getting towards GT3076R levels it's probably reasonable to expect it to respond like one - possibly a tad earlier but I'm only guessing .
You should probably compare that compressor map with the one of the real GT3076R 56T because while its peak efficiencies are very similar I like the 76R map . I did say recently on one of the American boards that Garrett's trend when they make higher flowing compressor wheels is to go up a family size of compressor housing because you get a larger diameter back plate/diffuser section and a larger radius volute passage . From maps I've seen this tends to widen the islands and increase the gap between them . When they are all close together I think its telling you that they are getting rapid changes in thermal efficiency over a short distance on the mass scale which to me indicates its not a wide ranging thing .
Maybe these things need a T04S housing or even one of the slightly smaller ratio GT40 ones , it means more bulk and weight and dunno if Garrett want to go there . If you've got time look at the GT4088R compressor map because they are really nice though more than you're looking for . The significant things are the small wheel trim and the larger GT40 0.72 A/R comp housing and although OT the 78 trim turbine size .
The 0.82 housing , if it really is the Garrett GT30 one , should work well but I wouldn't go looking for boost at 2000 revs . I think the go is to improve the engine itself so that it makes a bit better torque off boost and be a bit more seamless to drive .
A .
the max for internal gate gt30s on standard manifolds seams to be anywhere from 260-310rwkw on normal fuel. it varies a fair bit and theres no garuntee you'll see 300rwkw with that setup. the compressor side is certainly capable at higher boost levels (i suspect you'd need more than 20psi) but the exhaust side starts to get fairly restrictive at 300rwkw, mainly because of the standard manifold.
Ill be doing a direct bolt off/on comparison between the GT35 and GTX35 in the coming months.
Waiting to see a result, as I am getting tempted to ditch the GT35 for the GTX35.
A result would be nice to look at first...
Mick
So I've been comparing the GTX3071R compressor map with the GT3076R and they are very similar. (to my very, very limited knowledge)
But the GTX3071 wheel is smaller correct? Thus making it easier and quicker to spin up?
http://cgi.ebay.com/...sQ5fAccessories
Turbine Housing- new T3 GTinternal WG with built in swingvalve W/Turbine Housing Clamp and Bolt Kit
The turbine housing certainly looks like the garrett one. Looks like it'll flow very well anyway.
I'm very tempted to get it. Guess someone has to be the guinne pig ay...
I just ordered a GTX3071R kit from Kudos Motorsports! I should have it in a week or so!!! http://www.skylinesaustralia.com/forums/public/style_emoticons/default/thumbsup.gif
Hey, guys
Has anywhere in Australia got stock yet? I'm looking for a GTX3071, and prefer supporting australia :)
Otherwise, is ATP the best bet?
Congratulations! Let us know how it goes!
ill have some results up for a gtx3076r fitted to a friends sr20det which used to be running a gt3082r (409hp 21psi) on wednesday night
hopefully it makes the same amount power at 19psi and comes on abit earlier - ill ask the tuner to put both turbos on the same graph if anyone wants?
Definitely. I'd be inclined to ask them to keep everything set as it was, but only tune the extra bit needed for the turbo at the same amount of pressure and get comparative readings. But that's me. :P
Engine spec as follows:
RB25DET Neo
PFC and PFC boost controller
Full exhaust
ARC intercooler
040 fuel pump
Z32 AFM
Cooling-Pro triple core alloy radiator
I still need to buy injectors. I'm unsure whether I will get the Deatchworks or the Bosch EV14 ones.
Head will be cleaned up and checked. Unsure if I will rebuild the rest of the motor at this point, not sure if it needs it (head is already off so difficult to test, but it looks OK).
I will be replacing the water pump while its out - toying with the idea of trying an electric setup. Would also put an oil cooler in if I try that.
Awesome, very very keen to see how that goes on an RB25 - should be good! :worship:
Any details on the engine spec?
Results:
SR20DET fitted with a GTX3076 .82 tuned with BP98 Fuel - 408hp @ 1.5bar
Well the GTX3076r looks to be identical to the GT3082r ! (both turbos were using the same rear housing)
Below is the Power and torque readings @ 1.5bar
The boost actually starts off at 1.4bar and creeps to 1.5bar toward redline
Thick line is Hi boost setting, Thin line Lo boost setting
It had almost the exact same power delivery
Below is a graph of both turbos
Thick line is the GT3082r which made 409hp at the same boost and 445nm of torque - Thin line is the GTX3076r - 408hp and 437nm of torque
Interesting..
Edited by snozzle
Results:
Interesting..
Has that been separately tuned to the same knock threshold and AFR with both turbos or just the new turbo bolted on and dynoed?
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
