I know that lol. I also say goodbye to my 350. I'm saying if I can shave a few hundred rpm off this current setup (messing with timings etc) I'd go from 95% happy to 100%
hehe well ye there is that. 350 is relatively useless in RWD though.
More is less in a RWD scenario for a street car. The sweet spot i found with my GTS-R was around 280rwkw. Had 370rwkw @ one point and that was just ridiculous.
Each car and set-up is different of course, takes a few runs in the hills to see what works and what doesn't :)
I'm still really happy with the way it turned out. If I could shave 300rpm of I'd be extatic. Yeh doing internals.
You can sell a turbo within a week and replace it with a GT3071, and then do the same once you build your motor. A motor is going to take you at least a year to get done, might as well trade it in on the forums for a plain old GT3071, at least that is what I would do. A year with a better performing car for maybe a few hundred lost max sounds like a great idea to me, being as its such a new turbo you should have no trouble selling it as well.
If 300rpm makes you 100% happy then why doesn't 1000rpm make you even happier? Seriously it makes a LOT of sense to sell the turbo off and get a smaller variant, in the short and the long term, E85 will see you getting even more power than you are now with a GT3071 with at least 800rpm less lag, seriously consider it.
Can I ask how avo got such a bad wrap? They have been in the business for ages. Who here has actually used them n was not happy?
Search the forums, lots of bad reports of their housings. I don't think anyone was bagging them as a business, just the housing they made for the GT30
Edited by Rolls
I can't afford it. Remove sell buy install tune. Cost too much.
Fair call, though if you remove it yourself (really not that hard, lots of DIY guides on here) sell it (for more than a GT3071 is worth) make some cash, then spend that cash on a ~$300 touch up tune you should break even.
Car would be off the road maybe a week or two max if you don't have any buffer cash to buy then sell.
Edited by Rolls
That bad?
No I just can't confidently answer the question regarding the actuator.
Also why not a gt3076
3076 is suited to higher power levels, a 3071 would be around a similar power level to your current turbo, but with bucketloads more average power, would be much faster on the street and on the strip.
Look on here for examples of power levels and graphs for the gr3071 in 0.63 and 0.82 rear housings.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__st__660
Edited by Rolls
No I just can't confidently answer the question.
3076 is suited to higher power levels, a 3071 would be around the 250kw mark, but with bucketloads more average power than your current 270kw, would be much faster on the street. Would be faster down the quarter and much much faster on the street.
Is a gt3076 really that Mich laggier then the 71. Compared to what I have now. Wont a 76 still be an improvement.
Or perhaps a .82 on a 3071?
Yes they will all be an improvement, but you don't want to go much over 270kw on your stock motor do you? Isn't that why you limited your current gtx to 270kw? hence a gt3071 would be the best choice for this power level, I'm not 100% sure if you would make it on the 0.63, there is a result in the dyno thread with that much but I'm not 100% sure you would be able to replicate it.
Basically you want the smallest turbo and smallest exhaust housing for your power level.
Edited by Rolls
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&do=search&fromMainBar=1
this should answer your questions
In that link I struggled to.find gt3071. Perhaps under a different name Turbo?
I wonder if avo will allow a change of mind policy under 3 days after getting it.
Is a .82 3071 really that much laggier over a .63. Is it reasonable.considering the little.bit more top end ill get? Yes. I stopped at that figure cost of internals.
I'm just trying to gauge were to go from here.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__st__680
Post 694.
That's pretty good isnt it? 3071 with. 82.
u want the .82.. 3071..
But y go backward..you want 1/4 mile times dont u?
If so the turbo is great its just everything else will need changing to match it :D
Probably too easily swayed by people.on here.
I may have an oppurtimty to swap stuff around. If I'm looking for same power. Less lag. What's the choice. Gt3076. 63? .82? Gt3071.82. Gt3071.63(seems a Tad small)
Wich one. What are ur thoughts between the above. Vs staying.with what I have.
Edited by R31Nismoid
yeah it gets confusing, you would just think your car is great if nobody told you different hey..i know I would..
Just figure out what u want and can afford..if you want 11 sec 1/4 mile i guarentee that turbo will do it..but it may be shitty to drive on the street and you will need to spend $ to make it happen
If you just want a tough streeter that is awesome everywhere and dont want to spend heaps more cash then you unfortunately have the wrong turbo..
Isn't a good 1/4 a good street dragger?
Edited by ShiftyTys
Call them, worth a shot, they might do it with a restocking fee, pretty good idea imo.
Basically you wanted 350kw, imo thats way too much for the street, 300 is the limit for rwd before you just get slower (more lag, less traction, very hard to drive) if you want 1/4 mile times and use slicks then sure that power is useable.
If it is a daily driven street car aim for 250-300kw with the smallest turbo that will make that power, I would be looking at the 0.82 GT3071 for this, if you use E85 then you can make even more power, I think I've heard of people doing 320kw with E85 on a GT3071
not to mention 250-270 doesn't need an engine rebuild, where as if you want to do 350 year in year out reliably you do.
1/4 mile lag isnt a big deal as you can smash the limiter on take off and then you are flat the entire way, on the street you are using half throttle and low revs etc.
Edited by Rolls
That doesn't come with antisurge comp housing does it. U wouldn't go 3076.63?
3071 82 or 3076 63
You made a fairly big investment in the GTX turbo, while I am not a believer I am also not one to tell you to lose money. Keep it if you believe you do want more power (and will have the money to get it) down the track.
Decide what you really want.. I think in the end you bought into an overpriced T67... Somewhat laggier than a 3076 but capable of more robust figures (we hope). The T67 is proving itself more and more often for an over 300 turbo and costs under a thousand dollars delivered.. How can you argue. The downside is the external gate business and the fact it has an enormous comp housing.
If you seriously have a change of heart I think you should simply sell your CHRA (core and comp cover) and swap out for your said replacement. Be it myself I have seen enough proof (2 alone on this website) to indicate the 52 trim 3076 makes the 3071 near obsolete. I still believe the 3071 with a .63 internal gate housing will be a good thing all round, yet think the 52t 3076 will be better. Ideally I would run the 52t 3076 with the Kando 10cm cock-up housing and a 44mm WG (tial MVR 44 etc), but welcome to 6boob land and lots of cash.
The words have been said, if you had nobody to tell you otherwise you probably would never have thought a down thought about it, I know I wouldnt. Maybe just leave it alone and tune in that 300rpm your talking about (could get more with a simple cam gear mod) and enjoy the process of penile extension while informing the masses of your GTX taaarrrbbo.
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
