The RE5 locks when cruising on light load but only in drive. If you flick it into manual it locks every gear. I have disconnected it for the street as the lockup clutch cant handle the torque/converter flare, but on the dyno I have 12v switched straight to the by-passed solenoid making the box behave like a manual. I may have to put a manual clutch or transbrake into it one day soon.
I believe the afm is like 3 1/4 " or sumthing. Plus I've gutted the afm. No 1" bar across the middle. Most people run pfc with an afm Which still has an inch of thick plastic to create turbulance etc. I duno. Look ideally Wed all have no pod filter and almost zero exhaust for altimate flow. Lol. If I can get 500rpm off with actuator fiddling etc. This will be an insane setup. 600hp full boost at 3500. That's like hard to even comprehend. Lol
WTF???
That's strange behaviour?? Pretty sure commodore torque converters dont do that. I thought the idea was that you dont want too much load when the torque converter is locked otherwise you will burn it out.
Hey scotty i have a similar 2 tonne barge, albeit a Subaru Liberty Gt spec B Wagon with the EJ25, i am running the GTX3076r with a 0.82 Tial rear exhaust housing and on a run in tune with 20psi of boost its making 274kw, just need to sort out some fuelling issues and will push the boost a bit more. I am running a 3inch exhaust with a 5inch body 100cell cat, there was no difference power when running with and without. Will also pass the visual Cat inspection. ;)
yours is a great build, keep it up!
Dont ask me Jeff, Mr Nissan designed it that way. :)
Its supposed to be sporty in manual mode so the converter locks to provide full power and economy with no flare. The issue is it slowly tries to lock over 2 seconds after the gearchange, which is fine at stock power and with the stock converter but with 2 1/2 times the torque and 4000 stall instead of 2500 it has no chance. Thats why I cut the wire to the lockup solenoid.
As the new vic hoon laws have come into effect I have decided to plumb the external back in today if I get a chance.
Want to sell your Tial .82? I cant find one anywhere, Tial are out of stock worldwide. :(
Nice
hahaha, thats a shame,
I brought mine on Ebay from a canadian seller.
He has plenty left:
http://www.ebay.com.au/itm/Housing-Tial-V-band-inlet-and-outlet-GT30R-82-A-R-/380188401314?pt=Motors_Car_Truck_Parts_Accessories&hash=item5884fe9ea2#ht_1331wt_907
Edited by NissTrust
LOL, I didnt look but yeah thats pretty insane.. Must be compensating for the price. Thats usually how average ebay sellers make stuff look more attractive on the surface
Absolutely do not want to start a shitfight, but did you consider a Kando 10cm housing? Had I gone Garrett I would have definitely used that housing.. its like $160 delivered! T3 and Vband out.. For that money it might be worth your trying (I know you fab your own stuff).
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290564386512&ssPageName=STRK:MEWAX:IT
I already have the Vband Tial adapter made so I would obviously prefer the Tial housing but that one shares the compact packaging I required. I know HKS managed to fit the T3 adapter but the Vband is hard enough to tighten in that tight space without 8 bolts to do up. Imagine putting a ship in a bottle using 17mm spanners. >_<
cut and shut the bell-housing and run a clutch with the auto behind, best of both worlds. Use the clutch pedal for take off then the auto takes over. Pretty easy conversion if you have access to a lathe and cnc machine..
Haha. Don't panick. I'm not running an Afm. Its there for good looks. Hence the gutting.
is it all sorted? been meaning to call but been pulling some crazy 6am to 11pm days for a week or so.
Nah. Going in next Monday for a few days. I've got a few other things I want sorted but I still needed to ask u a couple things. Do u mind if we have a really quick chat after 6pm tommorow? Or no good? Thanks heaps....
So instead of transbrake clutch in and use a two step or something to build boost in neutral then drop it?
Wouldn't a transbrake be cheaper?
That could get confusing LOL, but I like the idea!
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
