I have definitely thought about it, as you said Trent its only for taking off but I have been told the input shaft probably wouldn't handle it for long. The auto shifts gears fine with the lockup clutch manually engaged so it would work well.
Yeah i got mine a few months ago and i payed less than that delivered, i'd imagine its supply and demand working at the moment, the Ebay seller obviously knows there is a shortage out there.
I needed a v-band setup because of my rotated/twist mount on the EJ engine.
Manifold and fabrication courtesy of Racetec performance in Victoria http://www.racetecperformance.com/
Edited by NissTrust
I would recommend some heat wrap to prolong the CV boots life at the minimum.. I would want to think about something more serious heat wise if you are planning on doing some serious driving (more than a weekend project etc). Personally I would have opted for a skyward gate, yet am not sure of your constraints up top.
Very nice however!
let us know how you go with fitment on a 6boost manifold. i have the same housing but to suit a gt30 on a hks cast manifold and fitment is mission impossible in every regard. for example the edge of the t4 flange sits so close to the comp housing that i've had to leave one of the comp housing bolts out as it fouls. have fun with the lines....:thumbsup:
i trial fitted my manifold/turbo setup the other night.
and you are RIGHT! it is a **milkshake** to fit.
here are some pics of the bolts that look impossible to do up unless we grint some of the exhaust housing....
what your thoughts guys?
What exhaust housing is that you are using?
That looks so dodgy and is never going to be able to bolted up properly without some crafty ingenuity
its an ATP 1.06 divided rear housing and a 6boost divided manifold.....
$3400 later and the shit dont even fit..
Is ATP some sort of budget brand or something?
Clearly all they are good for is a paper weight. Honestly, i wouldnt have even bothered trial fitting that as its clear as day that its never going to work properly. Surely ATP could see that
I would send it back with the pics you have above and demand my money back. Go get a housing made by someone who knows what they are doing
I just found the ATP website.... seems they love their EVO's and Subapoo's :)
Edited by ido09s
well i rang kyle from 6 boost and he said he has sold around 15 of these set ups (not fitted any)
so not sure what other people have done.
ATP is not a budget exhaust housing if anything it cost more then the genuine garrett one,
Edited by BMYHOE
Looks like the holes on the flange were drilled way to close. Then again it bolts to the manifold.
From memory dont Garrett housings have notches where the nuts clamp down?
i think they do mate ill see if i got a pic of my old one..
So what made you chose the ATP housing?
i wanted a true divided manifold & exhaust housing set up. which is ment to bring boost on earlier (blah blah blah)
anyways my uncle is coming over on the weekend to have a look and see what options we have with the housing.
Kyle does some awesome work but every now and then i think he loses the plot and just tries to hard to help you out, which unfortunately ends up back firing.
A few years back we ordered an RB26 manifold to suit an R33 GTR. We made the unfortunate mistake of telling him that it was going into an S14 and he sent us something that he thought would suit the conversion. Turned out the turbo hit the bonnet as the turbo was way to far forward and it would also force us to have a custom dump pipe made. He then wanted pics and things to try and rectify it which we werent interested in, we just wanted an R33 manifold as we knew they worked. We could also use a stock GTR dump pipe to suit the turbo when the turbo was in the standard position as it fits quite easily when doing an RB26 S14 conversion
We ended up getting it sorted but it took some convincing to just get him to send us a stock position manifold.
I would send it back to him and ask for a refund. He cant deny you the refund as anyone with half mechanical knowledge would agree thats just not right. Just get the proper Garrett housing.
I have learnt that trying to save a penny here and there just ends up in tears a lot of the time and to do the job with minimal fuss is easier when you spend a bit more cash on the correct matching part, in this case a Garrett housing
Edited by ido09s
mate i understand what your saying, end of the day is i have not saved any cash by going this set up.
the manifold cost me $100 more and i had to wait over 5 weeks for the exhaust housing and pay more then a genuine garrett item.
so what your saying to return the manifold , turbo & housing??
i brought the manifold turbo & exhaust housing of kyle all at once,
Looks like there is plenty of room under the manifold, you could drill the manifold threads and fit bolts with nuts on the underside. Still have to spotface the housing for the bolts to sit though.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
