Where are you from?
If your in Sydney take it into MTQ in Wetherill Park, they are cheaper than GCG, and try a genuine Garrett housing on the manifold. It wont be the manifold as the flange is a standard sizing.
The housing needs some dents in the corners to accomodate the nuts. You might fix it by grinding this housing, but you might stuff it also, so its not worth trying until you confirm if there is an alternative that works properly
Or as someone else just said you could drill the threads out and use nuts and bolts but to me its still not right. Its much easier and less hassle to be able sit the turbo on a couple of studs and use only lock washers and nuts.
Call me fussy or silly or whatever you want. i like to build cars that are easy to work on and nuts and bolts when studs should do the job is just silly
Edited by ido09s
OK quit the nonsense, call Kyle and tell him what the problem is.
The simple answer is the housing needs to go back to ATP to have a machinist surface the bolt holes so a nut can fit in place. The housing was rushed and not finished properly, simple as that.
If ATP cannot do that for you ask Kyle if he can. If not, ask for a part refund on the housing and keep it OR buy the uber expensive GCG alternative. If you get a refund on the dud housing and get to keep it, you can find a place that can do the machine work for you, but don't be conned into going to that level UNLESS you have received some form of refund.
The comment about sending someone to China is absolutely correct.
i trial fitted my manifold/turbo setup the other night.
and you are RIGHT! it is a **milkshake** to fit.
here are some pics of the bolts that look impossible to do up unless we grint some of the exhaust housing....
what your thoughts guys?
Pretty much what others have found with that housing some years ago. pinch.gif
http://www.freshalloy.com/forums/showthread.php?t=186058&page=4&highlight=twin+scroll
Can probably grind reliefs in the housing if there is sufficient meat.....email Geoff Raicer as he has fitted at least one of these to a Subaru that I am aware of.
Buy a Borg Warner twin scroll turbo. :ph34r:
oi order one in march called up the supplier at the end of april - they still had no response from borg warner on stock so got my deposit back and went for this set up :wacko:
DOES garrett make a T4 divided rear housing for the GTX35? when i did my homework 2months ago there was not garrett t4 divided rear exhaust housings for the GTX35 turbo
Edited by BMYHOE
Don't bother trying to use studs, pull them out and use cap screws... Got a turbo with the same housing here and it's no problem.
ok ill defenly look at this, thanks.
anyone ever welded the turbo to the manifold lol jokes
The one here hasn't been used yet, another mate has been running his for about a year and another I am not sure now... As he had been running the chra for years anyway but then swapped housing and manifold setup for response etc speaker some where along the line
I had the same concern (and plenty of others) with the ATP twin scroll housing. It's certainly not a budget option - as far as I could find it was the ONLY option if you want a t4 twin scroll rear for a gt35.
I could have made it work but decided the swearing come time to try and get a spanner on the water/oil lines simply wasn't worth it - so I sold the housing and the gt35. A borg warner s300sx delivers nearly identical results with a much larger/easier to work on foot print.
Btw I spoke to ATP about the problem at the time and was satisfied with there response which I've included below.
Hi Nick,
Thanks for the pics.
We undestand your concerns and we want to address them for you.
We'll be very upfront with you and you can decide if it's good enough.
If it isn't, we fully understand. We thought since you took time
out to raise the issue, we would spend equal time to explain where we
stand on this.
First, we have always used a local US foundry for our castings and
work closely with them to manage the quality of these castings.
This particular model housing has been the most, stand out, difficult
to work with. Every single production batch of this part (and only
this part) has resulted in 1 or many cosmetic blemishes throughout the
casting. The issues are some or all of the things that you described.
It's partly part complexity, partly tooling, and partly competence
of this foundry's process in handling this particular part. We have
about 30 other parts that we cast at that foundry regularly and seldom
have any of these issues on those parts.
Cosmetically, we have to do a lot of "touch up" work to make these
housings externally presentable.
The coring process of these housings do lend themselves to some
internal porosity as well. Machining of these housings is also tricky
due to the particular wheel to casting combo being a retrofit.
Yes, we do know about the one dip near the tonque.
The good news is in the course of the past 5-6 years of producing
thousands of these (unpretty parts), we have yet to have a failure of
any kind. We also have never gotten 1 single complaint of it's
performance. In fact, most shop or tuner that has used this housing
in their TS kit has turned into a repeat user if their kit is in
production.
Most of these housings do end up in high end turbo kits that do get tracked.
If it eases your concerns at all, we absolutely stand behind the
product and will warranty it for 1 same 1 year peroid and fully expect
it to perform.
The geometry of the unit has been tested and proven over and over so
you should not be concerned there.
We have a lot of wall on that casting so sometimes when the porosity
is real bad on 1 spot (like on yours), we just weld it so make it a
bit more visually pleasing than a big pit. We do not weld or repair a
casting that has any chance of breaking through where we find the
overall structural integrity of the unit is compromised and risks
failure during operation.
Thanks again for writing and if you still have any doubts on this
unpretty casting, send it back for a full refund.
Otherwise, if you decide to keep it and use it, we stand behind it
100% in its operation and integrity.
Edited by DCIEVE
Do you have a Borg Warner S300SX (83-75 I'm guessing..)? If so, any pics or results?
my atp housing was exactly the same, forgot to mention it earlier. you just have to grind the corners a bit, theres plenty of meat in the wall there. iirc though you'll have to use nuts with a 14mm head, 17 wont fit.
ok thanks jonno, it will be play time on the weekend
WTF? A company selling you a product that you have to potentially f#$k up to get it to work????
Surely they would get the relief cut into them in the manufacturing process or atleast when it arrives at their factory before sending out the customer.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
