ah ok, well hopefully it will be on full boost before 4000rpm, i noticed micks gtx3071 took until 3800rpm ( correct me if wrong) which i thought was a bit late, cause mafia's came on full at 3200 which is big difference,housings may have been different.
The claimed 10% increase in flow doesnt seem to be true in that case, atleast on those boost settings and rev ranges, maybe with an external gate and E85 the hotside isnt as bad, and the compressor is able to get closer to its max efficiency then.
oh well ill see what happens with mine and then re-assess any improvements.
cheers.
With the GTX3071 the extra compressor flow was compensated by upping the cropped turbine wheel to a full GT30 60mm version. It seems to have made it behave like the GT3076 but with better response.
Scott this just isn't quite right on two points.
There have been several versions of turbos with different trim 71mm compressors and various turbines from 53mm to 56mm to 60mm turbines. (GT-RS, 2835, 3071wg, 3071 etc etc)
Mick's GTX3071 made less power everywhere than my GT3076 with the same tuner on 98 ron. Once Mick went to E85 the car was much more lively and definitely one of the nicest RB25 you would ever hope to drive (and it is a better drive than mine) however E85 would also give a similar leap in performance from my car if I cbf using it.
I do not believe the GTX is a step up in this frame.
I believe there is more to gain from his setup still, I wouldn't be surprised if he could crack 350 at the same boost with a bigger exhaust, good manifold or better intake/cooler arrangement. How else do you explain my auto getting the same power output as his other than the rear housing?
Give it some time, and a few more well sorted cars will be getting those kind of results. Mine is hardly maxed, still has a 3 inch intake, stock airbox and cut down cooler to cause restriction.
Compressor is maxed out is the explanation. You both made similar numbers on similar dynos with different AR turbine housings. Dyno variation is also a factor, your original number from the hi-flow you had were on the high side due to calibration issues of the dyno if memory serves so your peak number with the 1.06 Tial housing was pretty much right on the money imo on a DD dyno.
Mick's car is one of the best sorted RB's and without doubt it is the best one I have driven but I would bet my left nut he would have more power and earlier with a GT3076 on his car with E85.
ps. mine showed clear signs of restriction on the dyno on 98 ron, maxing out at 290ish.
When you say the compressor is maxed, that only means the compressor can't flow any more with the current setup, that can be caused by many factors though as you are well aware. (My tuner said the compressor was maxed at 300kw before the exhaust upgrade.) I have no doubt there are gains going to a larger intake but I literally can't fit it in there on my setup, even though its running a map sensor now. Peak power was only at 23psi so there should be room to move yet.
I was hoping to push it to 350 as that was my current goal but there are a few hurdles with parts design I need to address, I have no idea what that power would equate to on an RB but I would have thought the auto would rob a fair chunk of it. Perhaps the .82 rear just isn't big enough? I will know soon as I have one here to try out.
All in all its doing a great job for its size, perhaps I will go down the aftermarket cam path to reap more top end gains (the VQ25det only runs around 8mm lift) but my goal was to see what the stock engine is capable of and I would rather just get a bigger turbo I think.
Scott I don't think it matters quite so much whether you or Mick can (even if he wants want to) achieve 350kw. Application (road, drag, circuit) counts for a hell of a lot, as does whether it has suitable delivery to put it to the ground. A larger 1.06 housing and/or fabricated manifold and/or attention to reducing restrictions may yield a slightly different result, but I believe Wolverine in his assessment of the importance of E85 in that setup. I just don't think that GTX3071 has any more to give. I think any changes would alter the character and delivery, but not the number (if that is what is being chased).
I do consider the 71 vs 76 exducer is an important variable when talking about response. Haven't yet seen any of the GTX compressor maps, but going by the established characteristics of the GT series, the 71 will have to spin faster to do its thing. Wolverine's comparisons on the pump 98 tends to bear that out. Having said all that, I'd like to see Mick's setup with the 1.06 housing. Its midrange oomph is ridiculously good (and fun) to the point you'd wonder how/where/why there would be a need to make it any different other than to put it to the ground more effectively.
Then the thought of using a different spec turbo comes up. I'd think the GTX3576 offers a lot of scope for the person who wants more than a GT3076 or GTX3071 can offer.
I agree Dale, The compressor must be running out of efficiency so its a losing battle but there is always a little more in it. I enjoy fine tuning the setup for greater flow.
How the power comes on is equally important. The 1.06 comes on a little softer, more linear and as such the tyres don't seem to break traction easily. The auto/stally would help too. I really need to get the front diff in though, its scary in the wet in rwd.
I have a retune next weekend and plan to try out the United e85, perhaps I can gain a little more from that? I also dropped the water temps by 10 degrees, back to 80, it can only help I guess. Hopefully it will take a little more boost this time. The plan is to make a few Subaru owners sad at the dyno day I have coming up. ;)
  • 1 month later...
Just out of interest, here is a comparison done by E&H Motors in NZ using their 2litre track spec STI on the same boost level using E85 of a twin scroll GTX3076R versus a twin scroll EFR7670:
Really, how so? It outspools the GTX and makes more torque everywhere even running slightly less boost at points - the dyno plot I put in the EFR thread shows its also seeming more keen to make more power. Its basically like a slightly bigger turbo than spools slightly better and is a fair bit more responsive than a GTX3076R, making 200awkw by around 4200rpm on a 2litre on the way to making 415awkw with more to come. Its not a bad result.
The twin scroll .78 housing is pretty small for the 76 compressor though isn't it? It may be laggier but strangling it wont help the top end, the GTX results can't be compared to a T4 1.06 TS anyway. Shame they didn't try similar AR's, I wonder what the manifold differences were...
So after lots of mucking around i finally got my GTX35 Twin scroll set up running.
fitted to a Built 9.5:1 RB2530 on E85, Currently the car is on a EPA/Run in tune for bedding in & passing emissions for engineering, so its only reving to 5750RPM and running 12.5PSI. no power figure yet but estimate approx 350HP at the moment.
changing from the GT35 to this i believe it has better spooling im seeing 12.5PSI at 4000-4200RPM in 2Nd gear.
the old GT35 would hit 24psi around 4500RPM
the set up at the moment is 6boost mani,GTX35, ATP 1.06 T4 Divided housing, 2x trial 38mm external gates, 4inch dump then reduced to 3inch for 2x VRss commodore CATs (for EPA), solid lifter conversion etc..
My emission test is 4th July wish me luck all :3some:
Good luck, but will you need it running ethanol? Should pass emissions fairly easily I would have thought. :P
It sound like a very nice setup, got any pics?
Im hopefully going for my GTX3076 tune this weekend, not sure I want to push it too hard now since a head lifted and blew the head gasket. It was a big job to pull it all out for repair and L19 studs, don't want to do that again anytime soon...
thanks guys hopefully it passes first go so i can go onto change exhaust & tune her up, if not i might have to add anther cat LOL
im using caltex e flex fuel the cams are 264in & 272ex with 10.5mm lift so it will be interesting to see if it passes
having trouble loading pics ...
Edited by BMYHOE
Is your user name the same as your number plates?
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
