How would a GTX3076 go with a 0.63 rear housing ( external) assuming it had either water/meth or E85??
assuming it had 22psi, would it be a fail or quite good?
Edited by SliverS2
You have the perfect housing, don't change it to the .63 or you will have more issues with det than you have now.
I doubt your engine is that coated in carbon that the compression would have been bumped, Can you get a scope down there for a look? If it is just drop the head off and clean it up, if its not there are some serious issues with your setup Mark.
Im starting to think its to do with the tuner, he didnt take very long, most of it was done within an hour, on the graph its only holding 16psi and you'd think he would of said, "mate, there only mild cams, you got some issues with leaks somwhere", it even stalled on him on the drive home, i think fix up this leak and possibly change the wastgate spring for a 1bar spring and even replace the resonator and then retune with E85.
My standard GT series made good power at only 21psi with .82 rear and full boost is 3800 or something.... So no need for smaller rear I don't think...
how long would it take to clean the motor if your running ethanol? or would that matter if your running ethanol?
Mine had a little carbon on the pistons, a quick squirt of gasket stripper cleaned them right up. Its a 150,000k engine so it should have been fairly caked.
The ethanol wont ever ping with a good tune and it's cheaper to run than 98 now the price dropped. (United) Shame the only outlet in Qld is Warwick, how close are you?
How well did it hold boost in the high rpm?
Did it drop off towards redline?
It used to drop off too 18psi by red line, tuner said if we could hold boost up top it would crack well into the 400's..
Warwick? im pretty sure theres some close by , well 40mins away at kessels rd mt gravatt which is on the way to the city anyway. :yes:
That would be from the pump, so is it right in saying the tuner will tune it not on the egde to account for if the ethanol content varies?
United is at Warwick.
Ethanol variation isn't a problem, even 10% variation would hardly change the afr's. I guess I have no worries with it as I bought a wideband, perhaps you should lash out $200 on a gauge too if you decide to go with e85?
Every tune is rich on boost, how much so depends on what your tuner is comfortable with. The Jap tuners love 10:1 on petrol with shitloads of timing, here around 12:1 and a less aggressive timing map is the norm. Either of these tunes should have enough overhead for a fair amount of variation and it should never ping anyway. Just make sure your tuner has e85 experience (although most would by now.)
I'm running 19-20:1 on cruise at the moment with no adverse effects, no knock and good exhaust temps. Try that with petrol, it wont run well and you would f*ck your engine fairly quickly I assume.
You need to get out more.
Caltex goodna
caltex springfield
caltex yamanto
Caltex goldcoast (suburb escapes me)
Caltex upper m Gravatt
All carry Eflex. I fill up at the yamanto outlet regularly and have used most of the others.
Plans are underway for a major increase in outlets, A new plant is being built in north qld right now.
Once completed you will see a major increase in the number of outlets.
any word if this major increase will stretch to NSW?
Nation wide from what I can glean.
The plant is definitely under construction as we speak. A friend has a supply contract for parts for the new truck fleet delivering cane to the plant when it opens.
That is freaking unreal. More or less the only issue I have with moving to ethanol is its availability.
If its more readily available in my area and on the way to wakefield I would happily retune my shitbox to run it.
Anyway, GTX bla bla bla.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
