11 hours ago, Lithium said:
Good power!  But yeah, solid point @Dose Pipe Sutututu - its what, 100kw at 4000rpm???  That is possibly the least power I've ever seen from an RB30DET at those rpm! :O
it had a rajab intake before, last time when i saw a swap from that to this intake, the power curve changed from concaved with rajab to convex with this one, and from memory
this intake took over at 5500 ish rpm, id have to check
  • Like 2
On 15/07/2017 at 8:04 PM, infomotive said:
Then some E10 vs E58 1.36 AR  ( part run )
Hi @infomotive - cheers again for sharing all this :)  Is this car all done now?  Was this 655kw the final figure?
If so, was the GTW3884R a drop in swap for the T04Z - possibly even using the T04Z turbine housing?  I have a friend looking for ~1000hp @ crank (will be tuned on an engine dyno) on E85 with a 25/30 and already has a T04Z, this looks to me like this could be the most cost effective upgrade.  I assume this has pretty big cams too?
Edited by Lithium
  • Like 1
No problem. I did some runs with E78 but found the traction limit unfortunately. Don't think there would be a-lot of peak power left but expect to be able to bold the curve further as still no timing added over pump E10 settings. Normal 3 port controller maxed up top.
Identical turbo bar the compressor wheel. I simply removed the Z core and put W in for true back to back test.
Cams are small but not much of the head really comparable to typical RB.
  • Like 1
  • 1 month later...
Has anyone got any real world data or results on the new GTX3076 gen 2? I've heard anecdotally from friends that they are quite impressive and people are achieving good numbers with surprisingly small turbos, but I've not seen any actual results.
Got a mate im just waiting on to tune his gtx gen 2 3071 if that helps. should be soon. On a built rb25 neo
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
