fark i wake up this morning to find my car (crappy little car) window smashed and speakers, sub, amp etc stolen. must have been some little bogans as they even took a tiny bottle of rice wine and like 5$ of coins, they didn't attempt to steal the actual car though but they must have had took their time as everything was unscrewed not ripped out. this was in the Florey area but no one heard anything even with the house windows open (parked on street, outside house)
What is canberra becoming... i hear friends cars being broken into heaps recently even in the less crimey sort of areas like curtin. Will make sure to get a good alarm when the skyline comes but i reckon by then the little shits will start torching cars instead.
If anyone knows of any known dodgy bogans/bogan activity in the Florey area let me know :P
https://www.sau.com.au/forums/topic/344106-car-broken-into/
It sux. Alot of people on here can empathise because it's happend to them also.
Your right it's becoming worse and will continue too. It's just the moral fabric of society declining where tolerance is preached and punishment is lax. The do gooders can go lick arse
I have a bad temper, see red mist over this sort of shit. I have even bashed a few bogans southside. I also found the car of some wannabe's who tried a BnE and now they dont have a straight panel on their ride.
https://www.sau.com.au/forums/topic/344106-car-broken-into/#findComment-5547424
The police won't do shit, i reported this but there is absolutely nothing they could do, they didn't try to tell me that anything was going to happen either. If they do something they will hold your car for a while then take a few holidays so you dont get it back for some time. They basically force us to put baseball bats through their knees as the cops themselves will just give these criminals the 'slap on the wrist' and most of the time (99%) they will do it again no questions asked, while a good citizen like myself blows 0.025 (P's) on the alcometer and i get to go to court and i get a nasty stain when doing a police check/security clearance..... personally i approve very much when these criminals get their ass handed down to them by us. /walloftext
https://www.sau.com.au/forums/topic/344106-car-broken-into/#findComment-5547435
or karma takes care of business.
Don't know if you remember the multiple fatality at the lights in Fyshwick not that long ago. Car theives and drugo's !!
-> God took the lot out :P
They don't print that in the CT.
Edited by Sinista32
https://www.sau.com.au/forums/topic/344106-car-broken-into/#findComment-5547446
Probably won't do anything unless you pinch some amputated toes from the local hospital surgery dept. and plant them in your car; before the police report is done. :)
Diabetics have amputations all the time. :yes:
BTW, don't ask me what I'm on! :cool:
https://www.sau.com.au/forums/topic/344106-car-broken-into/#findComment-5547672
That f**k head broke into my car 2 weeks prior to that accident too...
po po didnt do shite... as usual
https://www.sau.com.au/forums/topic/344106-car-broken-into/#findComment-5549022
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
