Hey I've just purchased a new set of bc-br coilovers and I'm really wanting to get them fitted this weekend. Im not confident in doing it myself and I'm willing to pay someone $150 cash that has experience in fitting coilovers to come out to my place and help me fit the front and rear set. I'd take it to a shop but I simply don't have the time during the week to get it done. I'm pretty certain I have all the tools required to do it unless there is some special tool required to remove the old tein suspension. So all you would need to bring is yourself. I'm located at redbank plains and my number is 0433 373 183 so feel free to call me or send a txt. Thanks!
https://www.sau.com.au/forums/topic/344117-anyone-wanting-to-make-some-cash/
Silly question... did you do a wheel alignment? If you change your suspension it's a good idea to check everything is set correctly (or take it somewhere and get em to whack it on the machine) otherwise if nothing else you'll destroy your tyres in no time.
no alignment needed. the car was set to the exact height that the original coilovers were at.
There's enough play in all the suspension bolts that it will still probably need an alignment.
An alignment is what, like 50 bux? I'm used to 31 owners being too cheap to get one, but I expected more on here :D
I would certainly do a wheel alingment. At least for a tyre wear point of view. Why save $50 if you gonna spend hundreds on a new set of tyres due to uneven wear.
lol. movement in suspension bolts. in a 33 i certainly hope not. would also love to know where said 50 buck wheel alignments r done. that would be handy. although i do like my car to drive straight so for around 80 i just get fulcrum to do it. lol.
hmmm.... double wishbone might limit the effect but it will still be there to some extent. 50 bux/80 bux shame sh*t. I think quickfit charge me $70 or $80 normally for the liner (but it's a pr*ck of a job) and $50 for the XF.
Any modification to suspension can cause the alignment to be out, or can cause an already ill adjust alignment to be further out. If you were on the coast my work does alignments for $66.
Thanks guys for your advice. I'll definitly be getting a wheel alignment done after reading a few of your comments, especially since i've just forked out over $700 for 2 new rear tyres. I'll be able to get it done for free as the place i bought my tyres from gives me one free wheel alignment and puncture repair....yay ;) and thanks again to jutto for fitting the coilovers!
mate of mine does them on saturdays for $50 and $30 if your nice on the northside.
(camber adjustments too)
on the downlow though
Edited by PetroDola
Ty,
Give Bossman tyres at Archerfield a call. From memory he's pretty cheap for wheel alignments. It's only a quick run down the motorway for you that way :ermm:
the guys got a 1500 dollar wheel alignment machine, that can't fronts unless you take your front bar off :D
/ takes 5 days to do your tyres
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
