Personally i wouldn't trust a pump like that...
You know it's not 100% even if it may sound like it's working and act all fine, it still could be damaged inside and not be able to pump all the fuel that it used to...
It's not something worth gambling with y'know.
my 2c
  • Replies 41
People are mentioning pumps to me, but not giving me prices or how could get em off them if willing to sell em.
And having my car out of action is beginning to frustrate me.
The pump sounds like it is working, but didn't end up getting the car to start properly. I need to try turning the pump on with just a spare bitta pipe to see if it is pumping the fuel or not.
If necessary I'll fork out for the new walbro pump kit from Trojan, but thats $230 that I really can't afford to be spending, but will cos I want my baby up and going again.
Get back to me asap guys, getting tired, stressed and frustrated.
I haven't put a price on mine as it's still in Sydney and I don't even know if it's out of the car yet. Want to lay eyes on it before I say it's for sale and of course make sure its ok.
Sounds like you are after a quicker solution than mine anyway. Mine won't be home till early Dec at best.
Yeah I kinda knew to half expect this, my large issue is it's the only car I have. The lucky bit is it's summer and i can take my motorbike.
I'll just keep working on bits and dealing with them 1 at a time..
I'll let you know if still need info on yours Kat, but there was a couple of other offers, so guess will see what they say to me, else I'll fork over the $230 to Trojan and buy a new one from them - presuming can't get all working right with the old one.
The stock one aint a walbro. walbro aint japanese :D The stock one is a japanese nissan made one.
I'd be happy to check that one off ya Troy, any chance u can spin past mitchell sometime? Thing is I still dunno if mine has issues or not, cos it sounded like was working fine, I just gotta test it in the fuel.. it sounds like is pumping fine... just atm I hadn't got the car to start when first put it back in, and it def is submerged in the fuel... I'll give it a try tonight, and if still nothing, I'll take it out again and see that actually is pumping or wtf is up *sighs* don't want to buy or try a different pump if that aint the issue.
Nah sorry I meant I assumed I had a stock pump, and it turned out to be some Walbro thingy.
Mine's just sitting there doing nothing....but at this stage I doubt I'd be able to shoot out to Mitchell again...already done it twice in the past week, which is twice more than I'd like to lol...
I might swing out there after work on Friday though, but only because I usually find my way out civic direction that time anyway. Otherwise, no sooner than that sorry. At least that gives you some time to work out what your pump is doing.
Walbro is around $130 from ebay. I had mine delivered in 3 days.
http://cgi.ebay.com.au/WALBRO-GSS342-FUEL-...=item336293cfab
If the pump sounds like it is working, then you probably don't need a new pump. If you really think it's a fueling issue, take the fuel line off at the engine and stick it into a bottle. Turn the ignition on but don't start it, see if fuel is being delivered.
You only need a small amount of fuel to get it started.
AutoPro and Repco can also order in Walbro and Bosch pumps. I bought my Bosch 040 pump from AutoPro for $205, 2 years ago.
Pretty pos is right way, cos the pipes only reach so far, so can only go in one place.
I was gonna take it off engine side to test, but the hose is a bit heat damaged, I need to replace it in general, but it'll not need to be replaced today unless I take it off, but prob gonna have to take it off.
I'll double check feed and return, and that all pipes are connected correctly where they are meant to be, and see if get pressure.
Troy I can ride my motorbike out your way more to meet you if need it earlier than Fri, else can meet you here in mitchell or maybe Civic.
Thanks heaps for help guys, just gotta work out exactly what the prob is then follow that up with one of the solutions.
Oddly Autobarn cannot order the pump in I needed, but at least the other places can if necessary.
I attached the connector back as it was. It only goes on one way. The thought crossed my mind, but it's a plug, and only goes on one way...
Thank you for checking my stupidity level though. If I had done that, my head would have a long visit with a brick wall in the near future.
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
