  • 1 month later...
has anyone got the "Torque" app running I cant seem to set it up right to get it to communicate :(
1) if so what protocol did you use.... from what I could find they said use ISO 14230-4 is that the (5b init, 10.4K baud) or the (fast init, 10.4k baud) ?
2) did you have to use the "alternate OBD Header" ?
3) did you use "Faster communication" ?
4) did you use "disable ELM327 auto timing adjust" (slow mode) ?
Thanks, Theo.
Thanks, Theo.
I think you'd be hard pressed to use the torque app...the OBLINK needs the "OB Bridge" app to communicate...maybe that app deciphers the info so the Carscope app can display the data?
  • 3 months later...
Bit of a thread revival; I spotted this on Kickstarter today https://www.kickstarter.com/projects/obdsol/obdlink-mx-wifi-a-wireless-gateway-to-vehicle-obd it might be worth backing. Sounds like it supports a wide variety of protocols; can anyone confirm the one our car actually uses though?
