R32 Gts-t Track Car Stripped With Loads Of Gtr Parts.
hey mate,
how much are u after for these
Set of 4 x white 17 x 8” and 17 x 9” 35mm offset jap racing wheels with worn Dunlop D02 on them.
thanks
I wanted to clean them up first to see how they look and possible get them re-sprayed and or re coloured. Currently they are white. I surpose $600? I was going to spend $200 on them and restore them back to new and look for more. If you are local come take a look if you are keen.
  • Replies 57
OK the following stuff is SOLD.
Rear calipers
Rear Rotors
Bonnet
Seat
Lights and blinkers
SUSPENSION ADJ COIL OVERS (PLEASE NO MORE PM's!)
Gear Box
Tail shaft
Rear pods
Exhaust
Turbo
Diff (all of it)
18 x 11 Wheels
18 x 9.5 wheels
DS2500 Ferodo pads
I have a deposit on the following which will be picked up tomorrow.
Front Adj Camber arms. Being posted tomorrow
Front calipers and pads
Rear Brace
Oil cooler kit
Set of white 17 x 8 and 17 x 9 wheels
The GTR brake conversion kit has also been removed
Thanks all, I now have my garage back!
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
