This has always puzzled me....
I know the following have the 6 speed getrag gearbox:
R34 GTR
M3 EVO
E39 M5
Supra, Non VVTI/VVTI
Mitsubishi GTO
Are there others that use it?
Anyway, are the boxes all the same? Ie interchangeable... Someone know? Cheers.
no?
No they are not interchangeable, and in most cases are completely different gearbox designs between different cars. Getrag gearboxes usually have an integrated bellhousing, i.e. designed to fit a specific engine block and can't be removed. Because of this, even gearboxes of the same model, e.g. Getrag 260, will not be interchangeable. The Getrag 260 was used in VS (series 3) / VT / VX / VY V6 Commodores, Beamers and Jags...yet they are not intercompatible between the manufacturers (unless you wanna do some cutting and welding conversion work).
Your Supra uses a Getrag V160 or V161, for reference. I am not certain if this gearbox was placed in any other vehicle, but I doubt it.
Getrags also have the wonderful advantage of being European and therefore rather expensive to repair.
S15 uses an Aisin 6 speed, which has an integrated bellhousing despite being much the same gearbox used in the Lexus IS200, Mazda MX5, Mazda RX8 and Honda S2000 :rolleyes:
Aisin also produced the 6 speed used in the VZ Commodore V6.
Also, the S15 gearbox is not that weak - two bathurst 24 hour races, several endurance and we've never broken one. People just like to drift with triple plate clutches and 250rwkw through a drivetrain that was originally designed to handle 180fkw~ from factory in a lightweight sports coupe...
Yeah, not a fan personally...I've sold heaps of S14 gearboxes to S15 owners who are under the impression the S14 is much stronger. I don't know where the consensus came from...I disagree, but am happy to take their 6 speed off their hands.
In my opinion the Aisin is a much better box all round. The only advantage of the S14 box is that you can install a PPG gearset in it. In standard form though, it's still just a small sports sedan gearbox and nothing that I'd want to go drifting with anyway...let alone downgrading retrograding my S15 and losing an overdrive.
ya but for track purposes, 5 speed is much better supposedly...even same with the 34 gtrs....they convert to 5 speed for better gear ratios and power along each gears....
There's a cheaper way to make the r34's move a bit quicker than having to convert to 5sp.
I see...
I would have thought the same as you Birds.
The 6 speed in the S15 seems very good.
Has "a" Getrag 6 speed...your focus uses a transaxle which altogether is very different from the rest of these RWD platforms...the Calibra Turbo also used a Getrag 6 speed transaxle in AWD form.
And look how well THAT turned out...lol
Hahaha well, transfer case aside, the gearbox isn't too bad :laugh:
More of a cruiser than a performance vehicle though. I'd never run insane amounts of power through one of those cars.
R34 GTR
M3 EVO
E39 M5
Mitsubishi GTO
Depends 'which' 6 speed you're talking about.
I know there's a 420G used in the BMW E39 which is a gearbox for RWD. The 6spd 466 AWD transaxle series is in lots of Porsche's, Audis and the GTO, the 448 6speed AWD transaxle tends to get used in the upper end Porsches. For what its worth, they are capable of holding big horsepower around 450 or so stock and after that they do need some (relatively inexpensive) bracing modifications to the housing and transfer cases, if you do manage to break one they do cost a veritable fortune. Most people break them because they're terrible, the boxes themselves are actually quite good! :(
In my experience a lot of them aren't interchangeable if that makes it any easier for you. The very hard way is to contract Getrag and be prepared to go slightly crazy in the process...
Edited by MK2
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
