This has always puzzled me....
I know the following have the 6 speed getrag gearbox:
R34 GTR
M3 EVO
E39 M5
Supra, Non VVTI/VVTI
Mitsubishi GTO
Are there others that use it?
Anyway, are the boxes all the same? Ie interchangeable... Someone know? Cheers.
no?
No they are not interchangeable, and in most cases are completely different gearbox designs between different cars. Getrag gearboxes usually have an integrated bellhousing, i.e. designed to fit a specific engine block and can't be removed. Because of this, even gearboxes of the same model, e.g. Getrag 260, will not be interchangeable. The Getrag 260 was used in VS (series 3) / VT / VX / VY V6 Commodores, Beamers and Jags...yet they are not intercompatible between the manufacturers (unless you wanna do some cutting and welding conversion work).
Your Supra uses a Getrag V160 or V161, for reference. I am not certain if this gearbox was placed in any other vehicle, but I doubt it.
Getrags also have the wonderful advantage of being European and therefore rather expensive to repair.
S15 uses an Aisin 6 speed, which has an integrated bellhousing despite being much the same gearbox used in the Lexus IS200, Mazda MX5, Mazda RX8 and Honda S2000 :rolleyes:
Aisin also produced the 6 speed used in the VZ Commodore V6.
Also, the S15 gearbox is not that weak - two bathurst 24 hour races, several endurance and we've never broken one. People just like to drift with triple plate clutches and 250rwkw through a drivetrain that was originally designed to handle 180fkw~ from factory in a lightweight sports coupe...
Yeah, not a fan personally...I've sold heaps of S14 gearboxes to S15 owners who are under the impression the S14 is much stronger. I don't know where the consensus came from...I disagree, but am happy to take their 6 speed off their hands.
In my opinion the Aisin is a much better box all round. The only advantage of the S14 box is that you can install a PPG gearset in it. In standard form though, it's still just a small sports sedan gearbox and nothing that I'd want to go drifting with anyway...let alone downgrading retrograding my S15 and losing an overdrive.
ya but for track purposes, 5 speed is much better supposedly...even same with the 34 gtrs....they convert to 5 speed for better gear ratios and power along each gears....
There's a cheaper way to make the r34's move a bit quicker than having to convert to 5sp.
I see...
I would have thought the same as you Birds.
The 6 speed in the S15 seems very good.
Has "a" Getrag 6 speed...your focus uses a transaxle which altogether is very different from the rest of these RWD platforms...the Calibra Turbo also used a Getrag 6 speed transaxle in AWD form.
And look how well THAT turned out...lol
Hahaha well, transfer case aside, the gearbox isn't too bad :laugh:
More of a cruiser than a performance vehicle though. I'd never run insane amounts of power through one of those cars.
R34 GTR
M3 EVO
E39 M5
Mitsubishi GTO
Depends 'which' 6 speed you're talking about.
I know there's a 420G used in the BMW E39 which is a gearbox for RWD. The 6spd 466 AWD transaxle series is in lots of Porsche's, Audis and the GTO, the 448 6speed AWD transaxle tends to get used in the upper end Porsches. For what its worth, they are capable of holding big horsepower around 450 or so stock and after that they do need some (relatively inexpensive) bracing modifications to the housing and transfer cases, if you do manage to break one they do cost a veritable fortune. Most people break them because they're terrible, the boxes themselves are actually quite good! :(
In my experience a lot of them aren't interchangeable if that makes it any easier for you. The very hard way is to contract Getrag and be prepared to go slightly crazy in the process...
Edited by MK2
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
