Just wanted to thank everyone for the great information found here on M35's without your info i wouldnt have bought one.
Just put down my deposit yesterday while they finish compliancing.
2003 M35 250t RS Autech
80,000k's
Aftermarket Alarm
Aftermarket TV/SatNAV/DVD Player. (Its a AVIC-XH9 all in japanese would love if someone had some info on this!) I am hoping if i cant get it converted to English i could at least replace the feed and keep the LCD).
The didnt come with cruise control which is unfortunate can anyone recommend a place in melbourne?
A couple of pics attached.
https://www.sau.com.au/forums/topic/344313-got-one/
  • Replies 57
import factory in Nunawading right? Looks familiar.
Car looks exactly like mine except for the front...still waiting for my aero front bar....
AVIC - sounds like a Pioneer product...if it is I'd head over to avic411.com and see if anyone's done a conversion.
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5549809
haha yes i thought the same Chris :D If i am lucky i will get to reuse the screen.
Ironpaw yup Import Factory. Thatnks for the link for AVIC411 will check it out.
Iamhe77 why isnt it an autech? (body kit looks right and it has the badge - though honestly i wouldnt know).
pic of interior attached. :blush:
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5551454
You have an aero front bar, but not the entire kit.
still looks the goods tho :D
the autech badge is becoming a mystery! it appears on aero models, but from what we can tell, only the AXIS model was done by autech.
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5551588
Sorry man, it has an Nissan "Aero" front bumper and the rest of the bodywork is pure RS.... plus the badge on the back says "RS"
An Autech Axis (that is what they're called) has a very different front bumper, grill, bonnet ornament, rear bumper, 18" wheels, Autech suspension and colour coded ARX type flared guards as you can see below
As you can see on the rear shot, an Autech has an "Axis" badge, certainly not an RS badge.
Edited by iamhe77
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5551814
Chassis number is 6u90000nm35318643
'u' could be an 'a' (handwriting).
So the later models have colour coded skirts and rear bumber? (i saw alot where these where all dark grey).
I was aware there is an AXIS AUTECH that looks like the pics above.. though i thought there was a AUTECH non axis as well that didnt have those features..
Either way i would have bought it regardless. >_<
So mine is all factory body except for the front air dam?
thanks WHT510.. you too! you bloody following me round or wot?? same cars in the past now the present.. same dealer!
yeah i think i saw yours.. black leather and aftermarket brembos?
Edited by Sage222
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5552730
The one I picked up has the aero selection kit which looks like yours (except for the front bar - I have the standard front bar...for now >_< ). I also got the Autech sticker on the boot and the "tuned by autech" sticker above the glove box. Don't ask me why/how...
Who did you deal with at ImportFactory? Did they go down much in price? I was looking at a JZX100 there a few weeks ago...
At least you got colour coded door strips...I really want to replace mine! Probably would be $$$$$ though...
Edited by ironpaw
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5552762
Well, f**k me! It IS an Autech :)
My apologies mate, I have never seen an Autech model without the bodykit & wheels before :)
lol... nearly 4 years of ownership and still learning :D
Edited by iamhe77
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5553324
:rofl: I wonder what on earth they (Autech) did to it :D
https://www.sau.com.au/forums/topic/344313-got-one/#findComment-5553347
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
