hey guys im having a couple dramas with my microtech..
im currently running a lt12S (annodised blue casing) ecu in with a plug and play harness .
Today ive spent 5 hours on the dyno, with my tuner and the ecu randomly keeps throwning up "MAP" errors..
this error appears randomly . the car is running consistant 17psi boost with no changes between runs and the error will flash up randomly.
If u disconnect and reconnect from the software you may get one power run before it flashes up again.
is there anything i can do about this . im running the stock map sensor (20psi) version that came with the microtech.
is it possible the sensor has failed. the vacuum source is connected directly from the balance tube with nothing else coming off it.
anyone had dramas with a map error before??? with a microtech
https://www.sau.com.au/forums/topic/344324-microtech-and-map-error/
