Finally took a pic of the first step in ramping up the looks of the interior
Im taking a more subtle approach, i think its all too easy to od on cf, so this may seem like no big deal for most, but in the flesh its a really nice touch and does the lift the ambience
The details - new gearknob purchased as i wasnt sure it was going to turn out right. However, blackmans in melb nailed it. Red Leather colour is very close and has the same perforated texture as stock seats (just cant be seen well in pic). Carbon is an overlay from RSW Japan. Fit is perfect, but if i had my time again i wouldnt have rushed into an overlay and had the original part wrapped....i still might when i get around to stage 2
What cant be seen is the dynomating of under the rear seat. I used half a trunk pack and got good even courage in one layer. Hasnt removed all the noise from stones, random diff/box noises but has reduced them by at least 50%. No more drone from my non-resonated mid-pipe either at low revs in tall gears - read gf auto mode
Stage 2 will be to remove the main bezel trim, wrap that in carbon and re-do the leather? lid in suede with red stitching. Just need to work up the courage to pull it all apart
Edited by domino_z
https://www.sau.com.au/forums/topic/344391-part-1-improving-interior/
I really like!
I shall be stalking your progress with interest.
ps can you please pm me your melbourne contact that has done the gear nob and cf? If I was to go the route of original part wrapped...who could do it?
the retrimmer in melb was blackmans
the rsw part i ordered from japanparts iirc, or maybe it was tunerlab.....either way tunerlab's doors are now closed anyway
the only people i know who can wrap cf is robson design in singapore, though its a hassle having to remove the part, send o/s and wait for it to come back whilst the car is off the road
hence why im trying to source a spare bezel surround trim atm to have wrapped
Just wrap it in cf vynil.
NeffyWrap is a carbon material perfect for wrapping. Much nicer than the typical stuff. I know a lot of guys using it both internally and externally, and by all accounts it's very nice to use.
I had a sample sent from the US, it feels nice and looks great.
Go to Google Images and do a quick search, as for some reason the forum won't let me place the images on here.
domino, we provide the same service as robson does at a fraction of the cost, let me know if yoour interested and ill get some quotes, my partner in taiwan does it.
empire, can you provide me with some pics of your work
Edited by domino_z
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
