What is for Sale
1989 R32 Gts-t Imported (190,000km), was imported with 165,000 and fresh rebuilt engine. driven around 25,000km in the 6 years it has been in australia, for 3.5 of those years it was off the road.
Modifications
Exterior
Custom Paint job in 2pac Orange
R32 GTR front bar
Genuine GTR bonnet & Grill
Vertex Side Skirts
Vertex Rear Bar
Volk Challenge 17inch wheels with Good Tyres
Interior
Pinoneer top of the range speaker front and back, sub and amp (all purchased when the car was registered in March of this year)
Pioneer Dvd Player with Ipod Adaptor
Mongoose M80 series alarm and imobiliser (ADR approved)
R33 Gtr Seats
Momo Steering wheel
Nismo Gear Knob
Engine temp Gauge
Blitz Dual Spec Boost Controller
Blitz Turbo Timer
Engine
Rb20 (built in japan just before being imported, supposed 2.2ltr build, never had a problem to even question the engines capabilities or strip it down)
rb25 gearbox
Hks Cam Gears
HKS twin plate clutch
Blitz Return flow Intercooler (custom piping)
Greddy Tdo6 20g Turbo kit and manifolds
Hicas removed
external wastegate & screamer pipe
3inch full exhaust sytem to a 5inch cannon
Apexi Pod Filter (enclosed in custom made box)
Apexi Power FC (with Hand Controller) (located in glove box)
Gtr Diff with racing castor Arms and custom LSD (came out of a 800hp engine package my brother bought from a half cut) handles the power with ease
Tien Coilover suspension all round
GTR brakes all round
there is alot more but thats all i can remember off the top of my head
It has just had a full service, all belts replaced and fluids changed.
270rwk 19psi dyno sheet proven, plenty more left in it was mapped for good fuel ecconomy in mind
car has cosmetic damage from two incidents at my work parking (happened in the last 3 months) where it was reversed into front and back. apart from that in very good conditon. (can work something out to have it fixed and repaired with potential buyers)
post-28922-1289814237_thumb.jpgpost-28922-1289814252_thumb.jpgpost-28922-1289814273_thumb.jpgpost-28922-1289814314_thumb.jpgpost-28922-1289814332_thumb.jpgpost-28922-1289814351_thumb.jpgpost-28922-1289814394_thumb.jpgpost-28922-1289814414_thumb.jpgpost-28922-1289814442_thumb.jpg
13,000 Neg
very regretful sale, i run my own business and work out doors and have been affected heavily by all the rain of recent and need to free up some cash flow, otherwise i would not sell peroid!
Cotact Info
Located Glenbrook NSW
Jeremy
0432344785
[email protected]
pm
thanks
https://www.sau.com.au/forums/topic/344405-1989-orange-r32-gtst/
i may consider run around and cash my way depending on the car, but i would rather an outright sale, i havent advertised elsewhere yet because i honestly dont want to sell it i could just use the extra cash right now.
any offers will be considered if they are genuine
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
