Leftovers from wrecking r33 series 1.5 all parts located in sa adel hills. clearing out for room.
lhs front gaurd $50
rhs front gaurd $50
rhs front headlight $50
gaurd orange indicators $10 pair
dash missing two small vents on top $80
center consol 40
heater/aircon control $40
heater $80
entire floor carpet $50
roof lining $20
center roof light $5
map lights $10
holy shit handles on roof $5
lhs a pillar $10
speedo cluster $80
glovebox $20
rhs sun visor $10
rear lhs tail light $80
passengers door$100 with all electrics
door linings and electrics can be separated along with mirrors
side skirts (one broken in half) $30 pair
windows (remove yourself or get removed properly) $$$
3"catback exhaust with emptied cat and rear cannon $200
interior lining $50
parcel shelf $20
boot lining $40
boot seal $15
bonnet latch $30
horn $10
fuel tank $50
rear skyline strip between lights $40
scuff panels inside doors $20 pair
fuel cap covering panel $10
windscreen wiper stalk $10
indicator stalk $10
steering column $20
rear rotors and calipers $150
front 5stud hubs $100 pair
standard diff $150
front suspension $50
rear subframe $200
r32 rear spoiler mspec 40$
r34 gtr front indicators (orange) $40 pair
r34 side indicators $20 (orange)
0419837474 prefer sms or call as apposed to pm, thanks
rear rotors and calipers sold
subframe sold
sideskirts sold.
rest offers on the lot, all taking up space. also brake booster availble too.
whats with getting text messages at about 4 in the morning after car parts......do people really sit on here and browse this early?lol....anyways still few bits to go..just using up room now..
  • 4 weeks later...
do u have passenger door for the 33 still ,if so how good is it paint ,dents,rust etc as i am pretty fussy thanks Darren
yep i just removed it then. i couldnt find any dents or rust on the door. the triangle section where the side mirror is inserted however has rusted, its not visible when the mirror is in, so if you were to treat it and apply an undercoat its not going to affect what you see anyway as its hidden.
the rest of stuff i really want gone so open to offers.
the shell has been sold sowhat i have listed in origional post is all available, prob a few bits gone since.
the entire steering rack i pulled out thismorining- also heater unit. (please no msgs like "will u post steering rack to syd for $100 inc postage" because no i wont. postage alone is probably more than 100$ so please no time wasters like i have previously"
so ...bump to see everything gone
Hey
is the mspec spoiler like a standard gtr one? (forgive my ignorance)
thanks
hey
the gtr spolier is not the same as the mspec. gtr spolier is u shaped and does not have a center connction to the boot. the mspec one i have connects at both ends of the boot and also in the center and is really only about a cm maybe a touch higher gap between spolier and boot. it also has a brake light inbuilt into it. which if you dont like can fibreglass up. if you want a photo sms me and il mms a photo through.5114250195_c60415c9ec_z.jpgthis is like the spoiler i have, in undercoat,
90blackgtst32.JPG gtr spolier
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
