Hey Hey,
I am currently parting out a Series 2 R33 coupe (Black) and have heaps of parts from it to clear as well as parts from a White Series 2 and some R32 gear.
I have a full rear cut with all the windows and rear windscreen etc, and a rad support cut as well.
Here are some parts i have for sale, and will advertise more when i get around to it.
Feel free to ask for anything as i will probably have it if its not written up.
#1 R33 Series 1 spoiler (black) $50 ono
#2 Unknown Brand Cannon $30
#3 Apexi BOV (ok condition, gr8 sound) $50 each (got two)
#4 Series 2 two door tail lights and rear garnish $100 (white)
#5 Series 2 dash (ok conditon) $100 ono
#6 Rear Hicas unit $50
#7 R33 fuel tank (gd condition) $50 ono
#8 Passengers Side Mirror (White) $50
#9 Passengers door trims (gd condition) $20 each
#10 Front hubs (LH and RH avaliable, 5 stud) $50 each
#11 Front Assemblies (knuckles and upper arms) $50 each
#12 Rear seat (ok condition) $30 ono
#13 Complete Dash loom $30
#14 Petrol Flapper/door $10
#15 Rear 2 door interior quarter panels $20 each
#16 Windscreen Washer Bottle $20
#17 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#18 Digital Climate control Unit (r33) $40
#19 Accelerator Pedal and Cable $40
#20 Set of 5 seatbelt for an R33 S2 $50 (gd condition)
#21 Steering Column with Barrel, Key and Trim surrounds $80
#22 Hks SSQ (gd condition) with rb25 adaptor $70
#23 Front RH and LH Guards (White in colour and gd condition) $80 each
#24 Reo Bar for behind R33 S2 Dash (Straight and good condition) $40
#25 R33 Engine Crossmember $50
#26 R33 Stock Airbox and Snorkel (gd condition and gd filter) $80
#27 Flywheel and Bolts $80
#28 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#29 R33 Brake Booster and Cylinder (no plundger) $50
#30 R32/33 Stainless Steel Intercooler piping $100
#31 Manual R33 Brake Pedal $30
#32 Heater core/Unit from an R33 $40
#33 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#34 S2 Pink Label AFM $110
#35 Stock Rear Bar for an R33 (need respray) $40
#36 LH Black Front Guard $80
#37 All S2 interior bits $ make offers $
Again any parts you can think of ill have, door seals, bonnet latches and cables, passengers door, rear garnishes, rear r33 strut brace, apexi radiator etc.
PM me anytime
ALL PRICES ARE ONO
Cheers Ty
Hey Hey,
PM me anytime
ALL PRICES ARE ONO
Cheers Ty
hi, i am in need of a drivers side power window motor, can u help me out >?
Please msg me asap on 0416840060 or [email protected] as i dont get on hear heaps.
thanks mate!
Hi,
I'd be keen on:
Passenger Seatbelt bits (mine doesn't auto-retract)
Climate Control Unit
Drivers Mirror (not whole mirror, just the shiny bit, if it's in good condition, as mine is scratched)
Posted to Gold Coast, QLD 4212
Just swing me a price and i'll let you know :)
hi mate cheers for the info on the clutch il take it off your hands just let me know how much all up if u can post to newcastle n.s.w i cant pm back cause my post count isnt high enough cheers mate
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
