Hey all
Alot of time and cash went into building this animal of a motor, The look on the few people's faces who have seen what this engine can do = pricless !!! Will not disapoint !!!
I have this advertised in my group sale but thought it needed to be put on its own.
Happy to answer any questions so dont hesitate to ask.
ITEM : BUILT RB24
CONDITION : NEAR NEW
INFO :
ENGINE HAS JUST BEEN RUN IN WITH A HKS 25/30 AND IS A ANIMAL!! ( Run in was done for 600KM @ 5PSI and no more then 4000RPM ) Once run in was done 20PSI and 8000RPM was set where it MADE 270RWKW & 840NM TORQUE WITH A HKS 25/30 !!!! DYNO PRINTOUT PROVEN. Engine will handle 9500RPM and over 600HP no worries.
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2MM HEAD GASKET
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
THIS WOULD MAKE A GREAT STREET ENGINE OR TRACK ENGINE.
CONTACT : PM ME
PICTURES : HAPPY TO SEND OR COME LOOK AT IT.
PRICE : $6800 ONO
https://www.sau.com.au/forums/topic/344466-built-rb24/
bit rich? i built my motor n it isnt even a rb24.. n it cost over this amount.. And this thing would be a fkn weapon!! Big thumbs up for being a bit original with it dude.. Shame ur sellin up. Good luck with sale.
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5566454
Just a bit rich for me personally mate, ie, I don't like my 32 that much :rofl2:
Free bumpage OP :rofl2:
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5570348
PICS
Also have a the dyno report which shows 270RWKW @ 1.7BAR and 840NM TORQUE with a HKS 25/30 !!
Sorry for the quality were taken in darkish warehouse using my phone.
Engine is sealed and wrapped , Just un rapped it for these pics.
Cheers
Edited by stylz7
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5574592
Motor is still up for sale guys
I can sell it on its own as a long motor or can sell it as a package which includes the following
RB24 long motor
custom front mount and piping to suit gtr plenum in 32 gtst ( would be hard to make the piping suit any application )
RB20 gear box in good condition
Autronic SM4 ecu with custom loom and sensors to suit this setup
HKS fuel rail and 580cc Injectors
HKS 25/30 turbo
Motor on its own $6500 ONO without the above parts
or motor with above parts as a package $10500
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5585046
Hi, cant see myself buying the engine as I am trying to sell all my Toney RB24 parts myseld. But interested to see a dyno sheet and difference between std RB20s with 2530s. That is certainly an impressive figure for a HKS 2530...but whatever the number, the shape of the curve would be interesting. Perhaps it will change my mind :)
Free Bump for a cool engine!
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5585061
$8000 for the lot guys !!!! COMPLETE PACKAGE
BUILT RB24
HKS 25/30
FULL PORTED HEAD
BIG CAMS
9L SUMP
AUTRONIC SM4
CUSTOM LOOM
RB20 GEAR BOX AND TAIL SHAFT
HKS TWIN PLATE CLUTCH
HEAPS MORE
$8K THE LOT !! YOU DO THE MATH AND SEE THAT THIS IS BY FAR A BARGAIN !!!
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5599518
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
