Hey all,
Today I tried to unlock my drivers door with my spare key to find that it wont open the door. I can unlock the boot and start the car with the key but it will not the door.
Funny thing is, my normal key (has OEM keyless entry) will open the door and start the car but will not open the boot.
Both keys look the same (in terms of cut) however my normal key is more worn.
Can anyone advise on why this might be and what I could do to get both keys to open all locks?
Also, I was talking to a mate about alarms today and he said not to put an "upgrade" alarm on my car as simply unlocking the doors (either by remote, by turnign the key or flickign the door switch) will disengage the alarm/immobilizer. Something to do with the solenoid sending out the pulse. Can anyone shed some light on this?
Note: I have the OEM keyless entry system
Thanks!
https://www.sau.com.au/forums/topic/344475-spare-key-doesnt-open-door/
if you put an aftermarket alarm on then you will need to unlock the car with the remotes that come with it rather than the OEM ones, as most alarms also have an immobiliser and pressing the button disarms it as well as unlocking the car.
Thanks mate,
when i was talking about the "upgrade" alarm, from what ive seen there are some systems which use the OEM keyless entry to run the alarm/immobiliser. He was saying that you cant hook our cars up to these as simply unlocking the car in any way will disable the alarm.
Oh well, im just going to get a full alarm system...
Isn't that the point of unlocking the car.. No point unlocking the car and still have the alarm enabled.. Talk to a proper alarm shop specialist about your options and whether you can program your OEM button to be used as your alarm/unlock instead of the aftermarket one..
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
